***SOLD*** ModWright LS 100 Line Preamp ***SOLD***
0 Members and 1 Guest are viewing this topic. Read 1145 times.
mreeter
« on: 19 Jan 2021, 01:42 am »
***SOLD*** Original owner, purchased new. Three years old, in excellent condition, an easy 9/10 on the A'gon Scale, and performs flawlessly. I take care of my gear and it will look as new when received.
An optional drop in, easy install, onboard MC/MM Tube Phono Stage is available from ModWright. See specs for details.
Will ship in Factory Carton along with Manual and unused Stock Power Cord. Everything as I received it.
The LS100 has spent its time in a dedicated Listening Space of a non smoker, no pets or small children.
Tube Complement: (2) 6SN7 driver tubes; (1) 5AR4 rectifier tube (may also use 5U4GB and 5V4GB).
Internal tube rectified, solid state regulated power supply.
Features: Four sets of RCA inputs.
One set of XLR inputs (wired single-ended).
Two sets RCA main outputs.
One set of XLR main outputs (wired single-ended).
One set of RCA Tape outputs.
One set of RCA Monitor Inputs.
One set of RCA Home Theater Bypass (HT/BP) inputs.
Two 12V remote trigger outputs.
Gain: 11 dB
Input Impedance: 38Kohms.
Output Impedance: 300 ohms.
Frequency Response: 20hz – 100Khz (+/-1dB).
Max input signal level: 10 Vrms
Max output signal level: 37 Vrms
Headphone Amp Power: 1.5 Watts (32 ohm – 600 ohm load).
Phono Option: MM/MC (Gain = 48dB/63dB).
Tube Compliment: (1)12AX7; (1)12AU7.
Loading: 50, 100, 500, 1K, 47K, 100pf.
Inputs: One pair RCA.
Dimensions: 17.75Wx17.5Dx6.5H (Shipping Carton 22X22X12)
Weight: 25 lbs. (31 lbs. shipped)
$2275.
At my asking price I will Cover PP Fees. Shipping is the buyers responsibility. I have a UPS account and only charge exactly what UPS charges me.
Thanks for looking!
« Last Edit: 30 Jan 2021, 11:45 pm by mreeter »
jjss49
Re: F/S Modwright LS 100 Line Preamp
« Reply #1 on: 20 Jan 2021, 01:01 am »
remote control?
mreeter
« Reply #2 on: 20 Jan 2021, 01:37 am »
Forgot to mention, yes.
Zkidd
« Reply #3 on: 29 Jan 2021, 11:17 am »
I think you sold this so perhaps mark the ad sold so no one thinks it is still for sale, yes?
Congrats on the sale!
mreeter
« Reply #4 on: 29 Jan 2021, 12:13 pm »
Yes, The LS100 has been SOLD, thanks for the heads up :thumb:
