Changes to Klipsch Cornwall IIIs.
0 Members and 1 Guest are viewing this topic. Read 5323 times.
S Clark
Re: Changes to Klipsch Cornwall IIIs.
« Reply #20 on: 22 Jan 2021, 12:17 am »
If you look at the before & after waterfall plots which were taken from one speaker in the center of the room. You will notice a ~50hz "lobe" in the before which is much smaller in the after. This is what I think is giving me the apparent reduction in "boominess."
I see the reduction.  Still, usually a bass boom is at a higher frequency.  I still think the issue at 75-80 is the more likely culprit.  The energy excitation at 50 is reduced in time, but it was never very loud... 25+dB softer than the 80 Hz peak.   That's like comparing a snap of your fingers to a shotgun blast.
The SPL at 50 Hz is so low that you won't hear much of a signal at that frequency at all.  Your speakers are dropping audible response at  that range, so it certainly wouldn't cause a "boom"
aceinc
« Reply #21 on: 22 Jan 2021, 12:44 am »
Do you have any way of displaying a difference on the waterfall plots so one can see just what has changed?
That would be an interesting thing to show. Does anyone know of a way of doing this in REW?
