Is it OK to plug one power conditioner into another during burn-in?
0 Members and 1 Guest are viewing this topic. Read 2375 times.
rippolito
First of all, Merry Christmas to everyone:  I hope you and your family have a good holiday.
I've purchased two power conditioners to audition.  Both require a burn-in period of x hours under some load.
Would you see any problem if I plug several loads into one conditioner, then plug that (loaded) conditioner into the other, so the load current goes through both conditioners?
Thank you, in advance, for any help you can provide...
Ron
thunderbrick
  • I'm just not right!
You are gonna fit in just fine around here.... 8)
fado
Bob2
:green:
twitch54
 :popcorn:
rollo
  • Rollo Audio Consulting -
 Merry Christmas. Yes but why not just install for desired use and break both in that way. You were planning on using both correct ?
charles
