0 Members and 1 Guest are viewing this topic. Read 4727 times.
This is exactly the sort of tweak I want to do - but I always figured it would be way too hard or too expensive to somehow get new wire into an existing house. My home power is all mixed up, with lots of noisemakers on either phase of my service entrance - and all 14-ga wire to boot.Sounds like some of you have either run new wire yourselves or paid an electrician - how'd it go, in either case?
As a code minimum, the conduit or raceway is relied upon to ground the outlet box. When non-metallic conduits and most flexible conduits (which do not provide an effective ground path) are used with IG receptacle, the NEC requires a separate grounding conductor to ground the outlet box
What if one is using a plastic outlet box, is this not kosher with IG?
