Is there a tutorial for isolation vs balanced transformers?
0 Members and 1 Guest are viewing this topic. Read 1106 times.
rippolito
I joined this circle primarily to learn more about conditioners that utilize isolation or balanced transformers, and how they differ from conditioners that don't utilize transformers.
Is there a tutorial that discusses the use of isolation vs balanced transformers, and if so, can someone please point me to it?
Thank you, in advance...
Ron
Big Red Machine
Re: Is there a tutorial for isolation vs balanced transformers?
« Reply #1 on: 22 Dec 2020, 02:08 pm »
Go to websites like Torus, PS Audio, Silver Circle, and Core Power to start.
What are you trying to achieve? All balanced trannys I ever used inhibited music to some extent, some more than others.
Check out Puritan audio. Non-restrictive. Best I have ever used.
BPT
  • Balanced Power Technologies
« Reply #2 on: 22 Dec 2020, 02:34 pm »
Here is some good information. "Lifting" the Grounding Enigma | Equitech
Chris Hoff
Speedskater
  • Kevin
« Reply #3 on: 22 Dec 2020, 03:28 pm »
While there are NEC rules for permanently hard wired isolation transformers wired as a Separately Derived Systems, there is a entire NEC Article on balanced transformers.
The Middle Atlantic white paper has a section on power transformers:
Darn, the new owner's have lost the paper!
