There is a Zu Audio Omen Dirty Weekend special going right if you do not mind the wait. Used Klipsch are another option.
Used to own a pair of DW’s and liked them. Why I’m considering Souls. I just prefer to try the Souls vs another pair of DW’s
Exactly. The only Klipsch's that "might" work with 2 watts would start with the Cornwall and move on to the Klipschorn. Still be limited in dynamics and missing any headroom to speak of. Fine if your entire library is girl/guitar and acoustic jazz trios.
What spl levels do you listen at?
I have a 45 based amp at about 1.5w and a 42 based at about 2wI currently only have a pair of Omega Super Alnico XRS towers and a 10" REL speed woofer. I love the Omega, but just looking for a second pair of speakers and maybe a bit more efficiency. I'd like to keep it under $1500 used, and was considering the Zu Soul'sWould love some recommendation to look up.
Two words... DIY and Altec! Its easier than you think and can easily make your budget.
One other thing you can try to squeeze more dynamics out of your current speakers is to use an in-line capacitor to roll off the mid/low bass before that signal hits your main amp. Then get a 2nd sub and run your bass in stereo. This will let you get the most bang for those 2 watts with those main speakers.
If you post your question in the Talkin’ Tubes section on the Klipsch forum you will get a very different, and far more accurate, assessment of using their speakers with very low power amps. Don’t believe anyone who tells you that you need higher power to achieve glorious results
I've thought about DIY with Coral or Lii drivers too
When I had H1s a 2 watt Grommes SET EL84 was more than enough in a 12 x14 room.
