The Denali was worthless. Sold it right away. YMMV
Over the past 7 years I have owned at least 8 power conditioners and all of them made improvements in my system but NO where near the performance of Puritan Audio Laboratories PSM 136!For the first time I’m hearing so much more information that has been buried by the barrage of ground noise; detail, ambiance, sound stage width/depth and note sustainment is remarkable by just adding this Puritan. I have also bought their ground master device that is said to remove the noise from your audio system ground to the supplemental rod that has to be installed. This modification has been completed and I’m waiting on the device to arrive to discern any notable improvement but I’m quite happy with the results of this unit!After listening to the youtube video, go to the 15:30 minute mark and see how much noise is removed even on dedicated lines...Wig http://www.puritanaudiolabs.com/products/master-purifiers/psm136/http://www.puritanaudiolabs.com/products/ground-master/https://theaudiophileman.com/ground-master-puritan-review/https://6moons.com/audioreview_articles/puritan/https://www.11stereo.com/https://www.youtube.com/watch?v=2VX4buciMLM
…[doing this] risks the potentially massive current from any fault between your HiFi and your local substation finding the easiest path to Earth through your HiFi with expensive, and possibly tragic, results! This is why the practice of introducing directly connected supplementary or dedicated HiFi Ground Rods is specifically prohibited
By utilising the Puritan Ground Master the hazards (and illegality) associated with the use of additional HiFi Ground Rods are totally avoided. …With the Puritan Ground Master used in conjunction with an additional Ground Rod the potentially dangerous route to Earth of mains frequency currents is safely isolated whilst offending noise and disturbance frequencies are permitted a highly efficient, extremely low impedance route to ground ensuring their elimination.
Has anyone tried the GroundMaster City?
Can someone explain how the "non-sacrificial gas surge protection" works on the Puritan PSM 156?If there is a surge, does it shut your components down. Then what happens?Also, what is the small black button located near the power cord inlet used for.Thanks for the information.
