Where are you plugging in your power amps?
Are there current limitations on each outlet on the PM156?I am wondering if I could just use one outlet on the PM156 and plug my UberBuss into it. That way, at minimum, I would get the advantage of my preferred AC receptacles. Possible product idea for Puritan: a smaller form factor PM device with one inlet and one outlet that could be placed before another power conditioner of another manufacturer - to get advantages of dc blocking, surge suppression, and AC filtering. Not sure if there is a technical downside to this, though.
Over the past 7 years I have owned at least 8 power conditioners and all of them made improvements in my system but NO where near the performance of Puritan Audio Laboratories PSM 136!For the first time I’m hearing so much more information that has been buried by the barrage of ground noise; detail, ambiance, sound stage width/depth and note sustainment is remarkable by just adding this Puritan. I have also bought their ground master device that is said to remove the noise from your audio system ground to the supplemental rod that has to be installed. This modification has been completed and I’m waiting on the device to arrive to discern any notable improvement but I’m quite happy with the results of this unit!After listening to the youtube video, go to the 15:30 minute mark and see how much noise is removed even on dedicated lines...Wig http://www.puritanaudiolabs.com/products/master-purifiers/psm136/http://www.puritanaudiolabs.com/products/ground-master/https://theaudiophileman.com/ground-master-puritan-review/https://6moons.com/audioreview_articles/puritan/https://www.11stereo.com/https://www.youtube.com/watch?v=2VX4buciMLM
@TomS and @wig, thanks for the info.I am not very clear on these requirements from safety perspective and when one claims insurance, so just thinking out loud - Does it need/have any certification (ex UL certification) or it is sufficient to say that it acknowledge the U.S. “Electrical Code” ?
Thanks, good information! BTW, I sent an email to them a few weeks ago, heard nothing.
