0 Members and 3 Guests are viewing this topic. Read 118496 times.
Does anyone connect high power tube amps (like 845/805) to the Puritan ?
Yes I do. My Hegel H590 is connected and it can deliver 2x 300watt /8 ohm (600 watt /4 ohm) . My dynaudio are 4 ohm speakers.Dynamics are fantastic.
So no one uses tube amps with their Puritan ?I am quiet happy with the performance of the PSM156. So far I had tube DAC and preamp and other solid state components (amps, servers, etc) all connected to it without issues. I hear all the audible benefits that others have described. I am not going into the details but suffices to say that the improvements has been quiet substantial in my system. However, recently I got a Line Magnetic integrated amp and when I connect to the Puritan, I hear a nasty buzz out of the Puritan. The buzz is quiet loud and can be heard from couple of feet away. There is also transformer buzz out of the LM as well. There is also a big hum/buzz out of the speaker. Apparently it looks like a ground loop issue but I can't figure out what would cause it as everything connects to the Puritan. Lifting the ground out of the DAC seems to solve the hum/buzz from the speaker but the Puritan still buzzes like crazy when the LM is connected. The only way to make it work is to connect the LM straight to the wall duplex where the Puritan is also connected. I am wondering if anyone has any thoughts/insight into it ?
So I played with this a bit and looks like the buzz is getting into the LM via ground - apparently it could be some ground contamination. The left two circular devices (not sure if they are the inductors or transformer or something else) is the source of the buzz and it get through the LM where the transformer starts buzzing and then to the speaker. I have not tried the Ground Master with the Puritan, but it’s possible that it might help in this case.@rareace, apart from buzzing, is the Inakustik AC-3500P an improvement over the Puritan in terms of sound quality ? folks here seems to think otherwise.
Here’s a list of conditioners I can remember owning:Torus CSShunyata SR Can’t remember modelAudience TS6Running Springs JacoCore Power 1200 with Furutech NCF Outlets, rewired with Duelund 600V Poly, home runs to each outlet eliminating the stock piggy-back config and Audience XO Cap on each outlet and all modified by me.Inakustik 3500PThe Puritan blows away all of the conditioners I mentioned above with ease.Wig
My thought is the transformer would help with isolation better.
Avoid transformers in your power conditioners. They can potentially rob you of dynamics and introduce noise that you're attempting to eliminate.
So you recommend going with more filtering, like the Puritan?
I don't think Wig had the Deep Core - only the Equi=Core if I recall correctly. So that comparison might not be completely informative to your question.
Thanks all. I pulled the trigger on a 156. Should be here next week.
Where did you purchase it?
@wig, do you know what is your wattage consumed when everything is powered on from Puritan ? I hear buzz from Puritan whenever a high power component is connected to it. Turn the component off and the buzz stop. So far two components created a buzz and both are tube gear. The higher the power the bigger the buzz. It looks like the Puritan doesn’t play well with some tube gear. I have heard similar buzz issues with Audioquest Niagara 5000.
