Over the past 7 years I have owned at least 8 power conditioners and all of them made improvements in my system but NO where near the performance of Puritan Audio Laboratories PSM 136!For the first time I’m hearing so much more information that has been buried by the barrage of ground noise; detail, ambiance, sound stage width/depth and note sustainment is remarkable by just adding this Puritan. I have also bought their ground master device that is said to remove the noise from your audio system ground to the supplemental rod that has to be installed. This modification has been completed and I’m waiting on the device to arrive to discern any notable improvement but I’m quite happy with the results of this unit!After listening to the youtube video, go to the 15:30 minute mark and see how much noise is removed even on dedicated lines...Wig http://www.puritanaudiolabs.com/products/master-purifiers/psm136/http://www.puritanaudiolabs.com/products/ground-master/https://theaudiophileman.com/ground-master-puritan-review/https://6moons.com/audioreview_articles/puritan/https://www.11stereo.com/https://www.youtube.com/watch?v=2VX4buciMLM
I've had many power conditioners including several "power regenerators," but none helped much with the noise in my system after dark. During the day I get pristine sound, but soon as sundown arrives it all goes in the toilet. Hope springs eternal. Where'd you get this unit and at what cost in $? Thanks.
Just had mine arrive today.
56
Has anyone come across a comparison between the 136 and 156?? I'm not sure which one best fits my needs.Thanks.
You can't go wrong with either but the 156 has 52 elements of filtering verses the 136 39 elements; the designers says the 136 is all most would need especially at the asking price but imagine more refinement with more filtering. My PSM 136 with the additional Ground Master gives me 51 elements of filtering and a bigger saving over the more expensive 156...Here's a testimony from Puritan user review section:
This is very helpful. Thanks!
I committed a cardinal sin but had no opportunity to place just one new item in the chain. I had a 156 and a Sachs Model 2 preamp show up at the same time with no other replacement units in house. Right out of the box this is the best sound I have ever had. Of course I cannot delineate which unit is giving me what exactly. I am on my way to 48 hours of run-in time for both used units just to reinstate the components to a burn-in state. Can't wait to roll some tubes. I have plenty of 6SN7's from the Dude preamp days to try in the Sachs. Amp is a VTV stereo unit with PR Sonic Imagery Labs 995FET Pro Opamp.Cleanest presentation I have ever had. Puts to shame the Luxman, Pass, and Inakustik combo.
Puritan Ground Master (GM) update!Guys,I received my GM on Friday night and was anxious to hear the improvements but knew it was going to be at least another 4-5 hours before the kids were in bed. So, I connected the device to the cabling running to the supplemental grounding rods and connected the supplied cabling to the GM and then into the my PSM 136 Star chassis ground which completed the installation (1 minute).Turned on the my soundbar to listen with the GM installed and uninstalled and the differences in clarity was even noticeable on my consumer soundbar. After getting the kids in bed, I powered up my system letting my tube components warm up for a bit before doing any casual listening but I was anxious to hear the improvements the GM was having in my system.It literally took no time to discern the impact of the GM; my sound stage grew another 4-5 feet in width, perception of depth also increased, transparency, clarity and low-level detail was quite stunning but this is the hallmark of having a lower floor noise… Images were rock-solid/tightly focused and tracking multiple performers on the stage were easily discernable within their own three-dimensional space.This GM is a bargain and does exactly as advertised, “Earth Line Interference Eliminator”. If you already have a 136 or 156, this device will elevate your gear to a level of unimaginable resolve. I understand the concepts of the Puritan but in my mind the PSM deals with all of the pollutants on your line within the unit itself and seems that adding the GM with a supplemental grounding rod, permanently drains ALL of the spurious noises emanating within the unit, your equipment and the main ground... This is a no brainer and Enthusiastically Recommended!Wig
@ TomSI bought a 100 Feet roll of 12 Ga stranded copper that's capable of handling 600 volts and more than capable of handling grounding duties; I used about 50 feet of cabling to complete my installation.Recommend saturating the ground for at least 30 minutes before pounding your rod into the ground, it will make the job much easier Wig
