0 Members and 1 Guest are viewing this topic. Read 7458 times.
That's a lot of cubic feet to fill with a 35 watt amp unless you just happen to have Klipsch Cornwall's or similar hidden away somewhere. With the speaker in question, (whatever it is?) it would be safer to move up to a 100 watt tube amp. This based on room + adjoining room total volume.....if I'm reading correctly.
AVA has a lot of fans and great reputation but I would not get a Dynaco ST70 based amp for your setup. Think kt88, kt120 based used amp. I think Jolida or Rogue would be best.
I have heard plenty of El34 based amps and had an ST70 at one point. Glorious midrange but lacking elsewhere.
Your Klipsch have a sensitivity of 98db. The AVA amp will play to ear bleeding levels without breaking a sweat. AVA offers a 30 return, so there is no risk and there is plenty of time to break it in.
In light of fact we now know the speaker in question, maybe the Ultravalve would have a shot. The only way to truly find out though is to take advantage of the 30 day audition period you mention.
If you are going to spend more money, you need to upgrade speakers first before thinking along McIntosh lines.
