SOLD: Musical Fidelity V90-LPS MM/MC Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 515 times.
onehotchili
For sale is my Musical Fidelity V90-LPS Phono Stage for MM/MC that I have had in my system for a few years.  It is a wonderful phono preamp and gets you into the vinyl game for a relatively low cost.  I am upgrading to a new preamp that has a built in phono stage and therefore don't need this one.
I am looking for $135 shipped CONUS.  Please let me know if you have you any questions... thx
From Musical Fidelity
The Musical Fidelity V90-LPS is an outstanding phono stage/amplifier designed to provide the ideal interface between high performance turntables and Hi-Fi amplifiers!
Overview:
The Musical Fidelity V90-LPS is an outstanding phono stage / amplifier designed to provide the ideal interface between high performance turntables and Hi-Fi amplifiers. Its signal path has been designed to offer a clean and transparent connection for your music to ensure it is heard exactly as the artist intended.
Housed in a sleek, attractive case the V90-LPS MM/MC Phono Stage balances high-end performance with incredible value and is the perfect partner for a wide range of turntables. It’s separate Moving Magnet (MM) and Moving Coil (MC) inputs are each tuned to offer the best possible performance from their respective cartridges and convey a startlingly realistic audio performance.
While the Musical Fidelity V90-LPS offers an outstanding musical experience it also represents amazing value for money. Listeners can look forward to hours of listening pleasure that is usually only delivered by considerably more expensive products.
Specifications:
• Input impedance: 47kOhm (MM), 100Ohm (MC)
• Input sensitivity: 3.0mV (MM), 0.4mV (MC) - for 300mV out
• Total harmonic distortion: 0.01% (MM/MC) - @ 1kHz, 300mV out
• Frequency Response: +0, –0.1dB, 20Hz to 20 kHz
• Signal / Noise ratio (A weighted): >80dB (MM), >80dB (MC)
• Input overload margin: 15dB (MM), 22dB (MC)
• RIAA response: +/- 0.25dB
• 1x 12v 500mA DC power supply
Connections:
• MM: 1 pair RCA sockets
• MC: 1 pair RCA sockets
• Line level outputs: 1 pair RCA sockets
• Power input: 1.3mm DC power socket
Outputs:
• 1x line level RCA (phono)
General:
• Dimensions - WxHxD (inches): 6.69 x 1.85 x 4.01
• Weight (unpacked / packed): 1.3 lbs / 2.4 lbs
« Last Edit: 30 Dec 2020, 11:41 pm by onehotchili »
