Capacitors
0 Members and 1 Guest are viewing this topic. Read 1324 times.
mresseguie
Capacitors
« on: 4 Dec 2020, 03:25 am »
I'm researching a potential speaker build, and I'm trying to figure out which capacitors to buy. I recall reading about a certain cap which I believe is called 'Vdam'. I've forgotten who the manufacturer is. I Google Vdam or Vcap, but I haven't found what I'm looking for.
Does anyone have a clue?
Tanks,
Michael
richidoo
Re: Capacitors
« Reply #1 on: 4 Dec 2020, 03:28 am »
mresseguie
Re: Capacitors
« Reply #2 on: 4 Dec 2020, 03:54 am »
ODAM, it is!  :lol:
VH Audio is the website that I was searching for, but not finding.
richidoo
Re: Capacitors
« Reply #3 on: 4 Dec 2020, 01:54 pm »
You might want to try the design with cheap parts first to make sure it sounds and measures right before replacing with hifi parts. Little tweaks far easier with $3 caps. ;)
