BDP-1 firmware update problem
0 Members and 1 Guest are viewing this topic. Read 1990 times.
GSDaudio
« on: 21 Nov 2020, 02:51 pm »
I updated the firmware today on my BDP-1 and TIDAL no longer works.
First the installation went well and I logged into TIDAL....it is a new way of logging in ..... all went well and the MEDIA PLAYER indicated I was logged in at the bottom of the right hand column interface.
I selected some TIDAL songs and it populated the left side as normal.
I hit play and got the following error show on the bottom right of the interface:
     TIDAL, OAuth access token missing
I checked the MPD log and it said the song was played:
     Nov 21 14:28 : player: played "http  ://localhost/mpd/tidalplay.php?Pop+Muzik-70743146-70743145-8913-file.flac"
Thanks for your help in advance,
Richard
jeffc24
Re: BDP-1 firmware update problem
« Reply #1 on: 21 Nov 2020, 05:23 pm »
I have exactly the same problem on my bdp-1 since the last firmware update.
Tezza009
« Reply #2 on: 21 Nov 2020, 07:57 pm »
I also have the same problem with Tidal since updating the firmware. Radio Paradise lossless is also unreliable. It worked fine previously. I have reported to Chris and waiting a response.
Is there a way of reverting to the previous firmware?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 22 Nov 2020, 06:00 pm »
Hi Folks,
This is a Chris question but on my BDP-3 Tidal and Qobuz updated fine.
I know Tidal changed some of the login requirements and Chris had to make some changes.
Maybe the BDP-1 is reaching its processing capabilities?
james
Tezza009
« Reply #4 on: 22 Nov 2020, 07:31 pm »
Previous firmware worked fine on the BDP-1 for Tidal and RP lossless. If we can go back to that I will be happy.
GSDaudio
« Reply #5 on: 22 Nov 2020, 10:43 pm »
Thanks for your thoughts on this!   I wasn't expecting a response on a Sunday!
I will wait for Chris to weigh in on the technical side.  Hopefully a quick fix.
Since Tidal and other streamers are ever evolving and the BDP-1 is not upgradeable......is there any hope for a Bryston BDP-1 to BDP-3 upgrade program like the 4B3 program?
Richard
unincognito
    • bryston.com
« Reply #6 on: 23 Nov 2020, 11:54 am »
Richard
When we updated TIDAL to use there new changes I had forgotten that we had to implement playback differently on BDP-1's.  I plan to release a firmware update that should allow 320kbps streaming, not sure how easy or difficult lossless will be to fix for the BDP-1.  I'm gonna try to dig up a BDP-1 here at work to test with.
Chris
Tezza009
« Reply #7 on: 23 Nov 2020, 08:57 pm »
Can I go back to the previous firmware? It worked fine for both Tidal and RP lossless.
jobiwon
« Reply #8 on: 28 Nov 2020, 09:43 pm »
Radio Paradise Lossless is completely unusable now on my BDP Pi.  Even makes some horrible screeching sound so I don’t even try it now.   My BOT-1 interfaces is also unstable.
