Sorry to beat a dead horse
0 Members and 1 Guest are viewing this topic. Read 2310 times.
Kw6
« on: 17 Nov 2020, 05:34 pm »
Hey guys,
Why does it seem that 2a3 tubes are falling out of and some prefer say El84 wired in triode?
Please enlighten me? Thanks 😊
Re: Sorry to beat a dead horse
« Reply #1 on: 17 Nov 2020, 07:11 pm »
Depends on the speaker.  If a speaker is higher than 93db efficient, then the 2a3 is a great choice.  Below 93db and the EL84 in push-pull is the way to go.
« Last Edit: 17 Nov 2020, 10:22 pm by Tyson »
S Clark
« Reply #2 on: 17 Nov 2020, 08:00 pm »
I've used 6bq5/EL84 (12-14 watt) amps on X-Statik speakers with excellent results.  They are in the 92 dB range.   On a pair of 88dB bookshelves, they are just a bit lacking in bass and control.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #3 on: 17 Nov 2020, 09:56 pm »
It is hard to make a bad EL84 amp.
An SE EL84 in triode outputs 1.5-2 w, an SE 2A3 closer to 3.5w.
An EL84 amp wil also be much less expensive. I’d guess even a good EL84 PP would cost less than a good 2A3 SE amp. I would expect cost to be why you suggest people ar egetting EL84 SE instead of 2A3 SE.
I am currently listenind to my mighty (3.2 w at clipping) PP EL84 triode amp and boy does it sound good (FHXL with MA CHN-110).
We did build a string of ever better SE EL84 amps, starting out with a Decware clone. We ende dup with a scade feedback arrangment which we liked better and it outout 4.9w at clipping.
dave
Kw6
« Reply #4 on: 18 Nov 2020, 06:42 am »
Ok thanks guys! Now the information is sinking in! ☺️
