Hi y'all, I have the classic cherry, love it. The oddity why I'm writing is this: the red ring for the speaker cables are opposite what I've seen forever (i.e. red here is on the 'left' side, looking at from the front). But, they're marked with the red ring, so, that one is easy. Red to red. HOWEVER! What about the xlr inputs? Mine are unmarked other than channel 1 & 2. Not helpful. Which is 'red' ? Right = red is opposite on the speaker cables, so what about the IC pattern?
"When using the front input" ...what is the front input? What does that even mean? "front side facing down" ...what does 'down' mean? Do you mean facing 'away' ? You're talking about binding posts. Why are you still doing that? Binding posts are for speaker cables. All I want to learn, for the 3rd time, in what seems to be plain english, is which xlr input is right & left. --Which is the 'left' binding post? Looking at this from the front or the rear, which is the left? But moreover, the xlr inputs are marked channel 1 & 2. Why this is, is beyond me. Why not mark them L & R ? The speaker posts are marked red on what to me is the 'left' side, opposite every other piece of gear I've owned my entire life. But again, at least they're marked with a red ring. The xlr have this generic label. This is frustrating, as I'm a UX guy, and you're getting feedback on this (apparently for the first time?).
If you connect channel 1 to the left input, then channel 1 becomes the left channel. If you connect the left input to channel 2, then channel 2 is the left channel. You can hook it up either way and get the same result. Just know that the corresponding outputs are above the inputs.
You can't explain it any clearer than that. Perhaps you can add -- "There's a 50% chance of hooking it up wrong. If you do, don't worry -- you'll know it when you hear it."
Well the good news is you'll go another 12 years before getting asked this again. Since everyone is on the edge of their seats at this point, I do get it now. Treat the entire column as either left or right, dealer's choice. That's what was throwing me. The blocks aren't independent but the columns are. We all see things differently. Or at least I do. So it goes. Heart the amp. It drives my giant PMC EB1i fwiw. Sounds amazing. Sometimes it's on my Zu Omen Def for kicks, in my other system. Anyhoots, thanks Tommy. Everyone else: show's over.
