Closed-High Efficiency Monitors
0 Members and 1 Guest are viewing this topic. Read 1694 times.
bixby
« on: 13 Nov 2020, 08:35 pm »
LOCAL PICKUP ONLY - Longmont, Colorado - $750 pr.
High Efficiency Monitors w/12 inch Full Range Drivers in reclaimed and upgraded vintage cabinets.
The Audio Nirvana 12 inch ferrite driver is an excellent representation of how good your music can sound when it does not have to go through a crossover to multiple drivers.  The driver is just over a year old or so.  Immediacy, clarity, coherence, scale, sound stage, attack, imaging all are impressive with great single drivers.  And since it is high efficiency you can run them with lower powered electronics especially tubes.  Driver specs avail on Audio Nirvana site. While AN state 95 db efficiency and we did play them off a 4 watt 2A3 setup in my friends small room, I feel a better match is about 10-20 watts or so, especially if you use EQ on the low end.
Dimensions are 25 in tall x 17 in wide x 12 in deep.
The cabinet is of a reclaimed vintage speaker that was built by one of Klipsch rivals so I am told.  It has a new thick and reinforced front baffle and uses heavy internal bracing and new damping material.   Port size and volume designed around the drivers. specs.  With this particular monitor sized cabinet, useable in room response can get to about 50 hz.  With EQ you can improve lower bass linearity and still have output some in the high 30’s.  If you wish more output in the lowest octaves, a sub is recommended.
This speaker likes corners for bass loading and height with the center of the driver about ear level.  Inputs are the fantastic sounding and secure Cardas Patented Binding Posts with Rhodium over Silver.    Decorative grills have been made and are included for those times when you are not listening.  They do not appear so “see thru” as they do with the flash pic.
Because the weight of these is about 45 lbs.or more each, local pickup is offered at Longmont, CO.
Enjoy a peaceful road trip to beautiful Colorado.
Message me with any questions and lots more pics in gallery link below.
« Last Edit: 7 Jul 2021, 09:26 pm by bixby »
bixby
bump to reflect re-list 12-17-20
bixby
Final Price Drop
Lincnabby
  • 520-548-8156
Hello-Is it possible to see some photos?
bixby
Hi:
Of course!  Posted at link below.
Keith
bixby
