Tube line stage to odyssey amp THUMP
0 Members and 1 Guest are viewing this topic. Read 3501 times.
I.Greyhound Fan
Re: Tube line stage to odyssey amp THUMP
« Reply #20 on: 24 Nov 2020, 03:35 am »
It should not change the sound much if any if you leave the amp on always but turn it off for 20 seconds while  you turn on your preamp and then turn the amp back  on.  All the electronics should still be close or at optimum operating temperature.  My Pass amp sounds best after  being on for about 45-60 minutes.  I have turned it off for a couple of minutes and turned it back on and have noticed no difference in sound.
owlsalum1
« Reply #21 on: 28 Nov 2020, 08:45 pm »
A thump is undoubtedly caused by the sudden appearance of a DC offset seen by the amp. It sounds like a thump because a DC step at the input of any amp causes a one-time big woofer excursion. Best practice is always to turn the amp on after the preamp has stabilized. Or, if the preamp has a designed in internal relay with a delay, ensure the relay really is cutting in when the preamp is stable.
You know you've got a real problem if you hear thumps occurring when both your preamp and amp are fully warmed up. Time to shut down and diagnose the problem at that point.
I've got a pair of Klaus's full up mono extremes with all the goodies in the works. Since I'm going to stick to his guidance by leaving them all the time, I'll be very cautious indeed first few times I fire up my system to put them through their paces.
