Replace Amp on MFW-15
0 Members and 1 Guest are viewing this topic. Read 9018 times.
friendswithdave
« on: 5 Nov 2020, 10:59 pm »
Hello All, first time poster, woo hoo!
I just bought a used AV123 MFW-15 subwoofer and noted it appears to have a bad amp. When turned on it produces a pretty loud hum, louder than a ground loop hum I think. I was going to search for this on here to see if others had this issue and knew how to fix it, but I need three posts to get to that, so HELLO! If anyone has a thread they can point me to, I would appreciate it. I actually have an unused powerful amp, but just need a little guidance to connect it to the sub.
Thanks - friendswithdave
HAL
Re: Replace Amp on MFW-15
« Reply #1 on: 6 Nov 2020, 01:42 am »
Get ahold of sandbagger here on AC.  He maybe able to help with the new MFW-15 amps.
Doublej
« Reply #2 on: 6 Nov 2020, 02:08 am »
Replacement amp - https://seatonsound.net/product/mfw-15-mk2-amp/
Possibly helpful for repair tips though not exactly the problem you describe:
https://www.reddit.com/r/audio/comments/4qvoqk/av123_mfw15_humming_fix/
https://www.avsforum.com/threads/advice-on-broken-av123-mfw-15-subwoofers.2545897/
Connecting an external amp - You need to disconnect the existing amp from the subwoofer driver terminals and then connect the external amplifier output (just use one channel if it is a stereo amp) to the driver terminals. If your amplifier is not a subwoofer amplifier you'll lose the ability to adjust output level, crossover point, phase etc.
Here are some external amplifiers designed specifically for subwoofer duty from $99. I know nothing about them:
https://www.outdoorspeakerdepot.com/amplifiers/subwoofer.html
Lastly if you have a local repair shop you could take it to them and see how much it will cost to repair.
Good luck!
sandbagger
« Reply #3 on: 6 Nov 2020, 02:22 am »
there is a fix that might work, its 4-5 caps as I remember off the top of my head and a bourbon in my hands so....
they are easy to replace.
If that does not work, its dead, do not spend any more time fixing the amp. PERIOD
Mark Seaton does get drop in replacement amps from time to time, he does them in batches though.  They are DSP programable for the stock driver or the Turbo driver.
PM me an email or google and you should be able to find the directions
friendswithdave
« Reply #4 on: 6 Nov 2020, 02:47 am »
Thanks everyone for the great info. I may attempt to change out the capacitors. If not (or if that doesn't work), it sounds like an external amp is the next step. I've bought used pro amps before so that may be my next step. I've never changed capacitors or amps before but I did find directions for changing capacitors and changing the amp as a whole should be even easier.
Thanks yall!
Early B.
« Reply #5 on: 6 Nov 2020, 03:10 am »
Don't replace one cheap plate amp with another cheap plate amp. Instead, buy this one:
https://www.parts-express.com/dayton-audio-sa230-230w-subwoofer-amplifier--300-813?gclid=CjwKCAiA4o79BRBvEiwAjteoYDUEpgY7I4boxoepoBzVE9cymusFip23T7Yy5bQSuA5jgG_V_LgXXBoCu9AQAvD_BwE
I own an MFW-15 and my amp went bad many years ago. I replaced it with the one linked above. Far superior in sound and much higher build quality.
petemoss
« Reply #6 on: 7 Nov 2020, 03:31 am »
I did the same thing and the difference was incredible.   the Dayton amp is so much better.
soundofrockets
« Reply #7 on: 7 Nov 2020, 08:54 am »
How easy or difficult it is to replace the stock plate amp with the external Dayton amp?
Additionally, can I split the signal from the processor and share it with the MFW 15 and the Triple OB servo subwoofer?
Early B.
« Reply #8 on: 7 Nov 2020, 12:53 pm »
Very easy --
Step 1: remove plate amp and disconnect speaker wire from it.
Step 2: unscrew one of the RCA inputs on the plate amp and feed the speaker wire through the hole. Use putty, duct tape, or whatever you have available to seal the hole(s). Reattach plate amp.
Step 3: connect the speaker wire from the driver to the binding posts on the Dayton amp. Connect a subwoofer cable.
Step 4: grab your favorite beverage, turn on some bass heavy music, and dial in your settings.
Yes, you can split the signal from the processor and share it with multiple subs.
soundofrockets
« Reply #9 on: 8 Nov 2020, 08:14 pm »
Thanks Early B - is the power from Dayton amp adequate for the MFW15?
I checked the PE website - there is another subwoofer amp rated at 1000watts - any experience or recommendation for this one with MFW 15?
I have two dysfunctional MFW 15 that needs new life.
Early B.
« Reply #10 on: 8 Nov 2020, 09:39 pm »
Yeah, you'll have plenty of power. Of course, you can never go wrong with a bigger amp.
soundofrockets
« Reply #11 on: 9 Nov 2020, 12:25 am »
Good to know - what about other features - will the MFW 15 woofer compatible with SA1000?
SoCalWJS
« Reply #12 on: 9 Nov 2020, 01:26 am »
I'll second this (if he's still around).
Upgraded my MFW 15 to his "Turbo" version with the external "Seaton" (Modified) Amp.
HIGHLY recommended. If it's still available, DO IT! New Woofer as well. HUGE difference.  :thumb:
soundofrockets
« Reply #13 on: 9 Nov 2020, 01:50 am »
Thanks John - just wrote sandbagged a PM.
What woofers are you using?  I have the default woofers in my pair.
SoCalWJS
« Reply #14 on: 9 Nov 2020, 02:28 am »
I don't know if I can find exactly - I know I commented here on AC many years ago when I did the upgrade. Still have photos in the gallery.
Quite a difference. Guess which one is which?  :green:
Early B.
« Reply #15 on: 9 Nov 2020, 03:37 am »
Yeah, I replaced the woofer many years ago. Substantial improvement. Try one of these:  https://www.parts-express.com/dayton-audio-rss390hf-4-15-reference-hf-subwoofer-4-ohm--295-468
The beauty of the cabinet alone was worth what I paid for the sub, but the amp and driver are low quality. Change those out and you've got a helluva sub.
soundofrockets
« Reply #16 on: 9 Nov 2020, 03:52 am »
My woofers are good for now - but if there is substantial improvements by replacing both the amp and the woofer - I will strongly consider swapping them both.
The SA 1000 amp is out of stock at the moment at PE.
soundofrockets
« Reply #17 on: 9 Nov 2020, 06:03 am »
Hi John - is the upgraded woofer on the left?
SoCalWJS
« Reply #18 on: 9 Nov 2020, 01:00 pm »
:thumb:
friendswithdave
« Reply #19 on: 12 Nov 2020, 02:10 am »
I have been having trouble identifying and finding the exact capacitors required. I'm leaning towards replacing the entire amp or selling it as is. Is there a market for these subs with bad amps?
