Just got my JVC F10....haveing trouble hooking up digital
0 Members and 1 Guest are viewing this topic. Read 924 times.
dman777
I just got my JVC F10 and am haveing trouble hooking up the digital part of it. I am connecting it to my soundcard, which has a digital line out, and I am useing an RCA Y coaxial cable hooking it up to the receiver DVD/DVR port in the audio section. I set the Digital Input 1 to DVD/DVR but there is alot of static in the speakers and I can barely hear the music. It works fine in Analog, this is only in digital. Any suggestions?
-Dman
TheChairGuy
« Reply #1 on: 5 Mar 2005, 12:04 am »
Try toggling the 'digital' button on your remote if your running digital in...it can only be done from the remote, not the receiver itself. Try that, report back.
I think I ran into a similar problem long ago that was solved with that.
