Headroom Mini with TOTL power supply Great Affordable Headphone Amplifier
0 Members and 1 Guest are viewing this topic. Read 504 times.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
This headphone amp is a bit of a sleeper. Has the crossfeed circuit that improves separation between instruments. Has a power supply that is about 3 times bigger than the amp section and built like a tank. The amplifier section itself is a bit light but takes up very little space. The only knock against them is the volume control could be a bit more refined, but it does get the job done. These are almost $600 when new in this configuration. Its in nice shape, a bit of mark on the bottom where some stick on feet were, and you might want to put another set on. I got a great deal on it, and will pass it along at $130, and it sounds like its worth more than that.
I apologize the flash highlights dust... But this room is kind of dark.
