0 Members and 1 Guest are viewing this topic. Read 82396 times.
Peter/Gordy,Is there a way to calculate the instantaneous current available from such a battery PSU as Peter outlined? I guess this is my only concern with regards to going full monty battery powered. Of course, most of my listening media has little in the way of dynamics, I still choose to not limit myself.
.....I'm of a slightly different mind than Occam on the value aspect. Having spent a good amount of time comparing the battery ps's vs. the diode/cap ps's with balanced power, I don't find the batteries wanting in any aspect and definitely superior in noise floor reduction. Where do you draw the $ line? ...
Peter(Speed),A number of issues -1. I don't believe its common practice to charge SLA batteries in parallel, unless they are charged with multiple bank chargers, which are actually multiple chargers which individually control the voltage ramping, but share a common underlying powersupply.2. You really need a 4pdt switch to also lift the ground(s). Inevitably, the ground is tied to other grounds via the interconnects on the amplifier, and mains ground which rarely sits at a real earth ground. Wor ...
Dunno where that line is drawn. The point I was trying to make is that when you can do the esoteric (SLAs) for less money than the mundane (transformers, diodes and bridges), its a no brainer.
What principally causes the failure of these batteries is the formation of sulphur salts within the batteries. Any wharehouse operation that uses forklifts, etc... as a matter of course uses desulphating chargers...
It helps to keep the cost reasonable, but I've essentially had it with AC power and all the expense that goes into cleaning it up. Dedicated coircuits, cryo outlets, fancy power cords, isolation transformers, Line filters, Auricap filters, better power supply caps, etc etc - that adds up and it just doesn't ever get good enough..
De-Sulphation of battery: The charger will remove loose sulfation and increase the battery life. (Hard sulfation cannot be reversed).
I guess, I have had this mental preconceived bias that battery power = less dynamics. I am glad to hear that isn't the case.
... have been simultaniously burning in a newly moded BG 'laden' battery dac as well. With about 80-85 hrs. on the dac and 110-120 on the amps things are really starting to open up, especially after the 60-70 hr. point on the dac! I stopped comparing the straight out Denon to the dac awhile ago... The BG caps for the batts arrived this am, less than 24 hrs. from Angela's!!! They're going in the chip amps today for 100 hrs. or so, guess the UcD's will be off until Tues. or so...
Excellent!, thank you Dr Minky. I have some cooking in a chip amp now, I'll give them a try starting about Wednesday. May I ask what capacitance(s) have you tried??? Thanks
