Choosing new caps for crossover upgrade
loic_emmert
« on: 28 Oct 2020, 12:59 pm »
Hello everyone,
I am interested in finding out more information about how to choose between brands of caps when looking for parts. I have seen a few posts mentioning that some make speakers sound more bright or mellow, but don't really understand why/how that is.
I am asking in preparation of upgrading the crossover of my JBL 4312As.
Thank you in advance for your help.
Best,
Loïc
avahifi
    • http://www.avahifi.com
Re: Choosing new caps for crossover upgrade
« Reply #1 on: 28 Oct 2020, 03:40 pm »
Because the value of a capacitor is what it actually measures, not the value printed on the case, always use a capacitor meter to check the capacitors you install. For example the actual value of a 10% tolerance 2 microfarad capacitor can be anywhere between 1.8uF and 2.2uF and be in spec.  This would change your system balance if you had installed the 1.8uF in one channel and the 2.2uF in the other channel.
For best results install the new capacitors as matched pairs, channel to channel, to make sure both channels are the same.
Wayne1
« Reply #2 on: 28 Oct 2020, 05:33 pm »
You may want to read through what Troels Gravesen went through when he rebuilt a pair of L-100s for a friend:
http://www.troelsgravesen.dk/JBL_L100.htm
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 28 Oct 2020, 05:42 pm »
  Adhere to Franks advice. To learn more about the sound signatures go to HumbleHiFi for their Cap reviews. Have fun.
charles
Wayne1
« Reply #4 on: 28 Oct 2020, 06:04 pm »
Another fun read is when Tyson brought his Klipsch Forte III to Danny Ritchie of GR Research to upgrade.
https://www.audiocircle.com/index.php?topic=166996.0
loic_emmert
« Reply #5 on: 2 Nov 2020, 01:51 am »
Thank you everyone for the help, it's greatly appreciated.
Loïc
Speedskater
  • Kevin
« Reply #6 on: 3 Nov 2020, 12:52 pm »
I have been reading about Kemet ALC10S Slit Foil Capacitors. They are designed for audio circuits (like crossovers) rather than power supplies.
https://content.kemet.com/datasheets/KEM_A4029_ALC10S.pdf
undertowogt1
« Reply #7 on: 3 Nov 2020, 03:19 pm »
Some interesting info here. Maybe it can give you an idea what to look for
http://www.humblehomemadehifi.com/Cap.html
