Vision Q Settings.
0 Members and 1 Guest are viewing this topic. Read 1043 times.
VinceT
Vision Q Settings.
« on: 24 Oct 2020, 06:26 pm »
I picked up a gently used Vision Q after hearing all the rave reviews to pair with my Dynavector 20x2L.
Just to make sure I am not screwing things up, switches up is on, down is off (cover off and switch panels to the right of the case). Switches 1 and 2 have to be on (up) to engage MC mode.
No matter what gain and loading I use in MC, I get a terrible scratchy/muffled sound like the Vision Q it is cutting out with very little output. I put it in MM setting by flipping all the switches down, sounds clear. I bypass the pre amp directly to the amp, sounds clear. Could it be something with the amp? I am using an old Marantz 2270 with this table and running into the phono.
Am I doing something wrong, or could it by an issue with the Vision Q?
« Last Edit: 25 Oct 2020, 04:34 am by VinceT »
TomS
Re: Vision Q Issue?
« Reply #1 on: 24 Oct 2020, 07:31 pm »
You'd want to run an outboard phono preamp into a line input on the 2270 such as tuner, cd, tape, etc. not the phono input which has too much gain.
VinceT
Re: Vision Q Issue?
« Reply #2 on: 24 Oct 2020, 07:43 pm »
I will give it a try.
Thank you
VinceT
Re: Vision Q Issue?
« Reply #3 on: 24 Oct 2020, 09:19 pm »
That was it
No issues with pre amp, user error. Vision Q sounds great.
Decided on 60 DB gain and 100 ohm loading for the Dyna 20x2 cart for best sound so far.
« Last Edit: 25 Oct 2020, 04:36 am by VinceT »
