Announcing The Bryston BR-20 Preamp/DAC/Streamer
Titanium and 11 Guests are viewing this topic. Read 483236 times.
amdan
Re: Announcing The Bryston BR-20 Preamp/DAC/Streamer
« Reply #740 on: 19 Oct 2025, 10:31 am »
I tried using the Bryston as a streamer and it is working so far. All is well!  :D
bokko
« Reply #741 on: 19 Oct 2025, 11:16 am »
I can say I have used the BR-20 USB input with:
PC several different systems over the years including a nUC on enhaced power supply.
Raspberry Pi 3 and 4 with enhanced power supply. BR-20 streamer definitely sounds better.
Eversolo A6, A8, A6 gen2 sound very similar as streamers. Will be trying T8
Wiim Ultra that was bought for stereo 2 gave it quick listen and retuned to stereo 2
The Eversolo A6 gen2 is being used as a streamer for more functionality with streaming services. I do miss the volume control that BR-20 provides in Roon.
A problem I have there is the A6 g2 is trigger out to trigger in on BR-20 to power up remotely. The BR-20 boots faster then A6 so need to switch away from USB and back before A6 will detect BR-20 USB port.
Presently use A6 G2 with both a coaxial spdif Cardas Parsec cable and Cardas Clear 1m USB.
Other then what was mentioned above I have never had detection problem beyond above with the replacement BR-20 or previous one.
bokko
« Reply #742 on: 30 Nov 2025, 01:43 pm »
Received the T8 and running it to BR-20 with a Cardas AES Clear .5m I purchased at half price from someone who needed a 1m cable in their new cabinet.
Have to say I like the sound better than with the Cardas USB Clear. At this point thats a minor improvement. Find it touch warmer, more spacious in depth and width of soundstage. I have compared it to a baseline Monoprice AES no comparison sound wise. Put it on Buy Nothing.
You can use Apple Music with Eversolo devices but have to say the interface is a little more clunky than Qobuz or Tidal. If doing it you need to make sure to use the App (from app section not streaming) to get above 16/44 actually BR-20 does 32/44. You are also stuck controlling it in Cast (Now called Screen) feature. Qobuz offered me $400 plan upgrade for 4 years of service and I abandoned Apple Music.
My question to Bryston is how much room do I need above BR-20? It never seems to gets hot or even warm. Presently have about 1” between it and shelve that T8 is on and would give more slack with cable.
BTW
For those thinking of a BR-20 purchase don’t let this post detract you from purchase the streamer in BR-20 has served me well since 2021. One thing it and Roon can’t help you do is play SACD iso’s directly without ripping to DSF per song files.
Interestingly enough when I listen to my SACD iso rips I do prefer still prefer USB connection. Maybe its the Native light turning on ;-)
For Apple Music you can also hook iPad or iPhone up directly to USB on BR-20 and have some control from your Apple Watch. Haven’t tried for a year or more
Enjoy the music
EvanMcC
  • Bryston, Dynaudio & Torus
« Reply #743 on: 3 Dec 2025, 10:02 pm »
I have had bad experiences using Roon to control the volume on my BR-20.   Several times the volume increased without bound, risking damaging the speakers.  I know others have had this issue too.  I don't know if it's been fixed.   I control volume on the BR-20 with the Bryston remote or the knob on the unit when using Roon.
You can set volume limits inside Roon to prevent damage from inadvertent volume changes. There's a comfort limit (for when using vol. slider inside Roon), and a safety limit that Roon will never surpass.
There are also limits inside the BR-20 menus that affect all inputs, not just Roon.
Good luck.
amdan
« Reply #744 on: 17 Jan 2026, 10:07 pm »
Hello. Is it possible to connect the BR20's streaming output to an external DAC whose analog output is then connected back into the BR20? In other words, I would like to use my  own DAC instead of the the BR20's in-built DAC.
jcn3
« Reply #745 on: Yesterday at 09:00 pm »
The streamer is a RPi and the Pis USB ports are accessible,  so unless Bryston has done something with the firmware,  it should (could) work.
If you don't own the BR20 already, then I would buy a BR19. You can get a decent streamer for less than the $1800 difference in price.
