Announcing The Bryston BR-20 Preamp/DAC/Streamer
bokko
Re: Announcing The Bryston BR-20 Preamp/DAC/Streamer
« Reply #720 on: 9 Mar 2025, 12:53 am »
Clive I think that might be because firmware update requires you to reset defaults during procedure.
Mine is set low on purpose when dog goes upstairs I crank it.
Don’t wanna deafen the mutt.
avsrb
« Reply #721 on: 23 Mar 2025, 03:36 pm »
Dear Bryston staff,
Some time ago, there were some rumours about Tidal Connect coming to the Bryston streaming world, incl. the BR-20.
May we have some news on this front? E.g. is it on the roadmap / planned, etc.?
As an owner of multiple Bryston products, and a user of Tidal Connect (amongst other app-driven platforms), the only thing that discards a BP16 -> BR20 upgrade (and more) is the lack of Tidal Connect. At least if it not comming, would be "nice" for such a passionate user base to know!
Alexandru
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #722 on: 23 Mar 2025, 03:38 pm »
Hi Alex - can you email Adam on this please - [email protected]
avsrb
« Reply #723 on: 23 Mar 2025, 07:29 pm »
Just did, James, thank you.
JfTM
« Reply #724 on: 2 Apr 2025, 12:26 pm »
Is there any way to stream WWOZ (from New Orleans) using the BR20?
Using bRadio?
If I can I can get rid up the laptop I’m using now.
« Reply #725 on: 2 Apr 2025, 06:04 pm »
Ask Chris please - [email protected]
grmtz
« Reply #726 on: 16 Jul 2025, 09:14 am »
I am a bit confused and want to clear something up: James Tanner, you mentioned that you should not use device volume in ROON to control volume in the App, but I don't think this is correct. With device volume configured, ROON will adjust the analog volume control, not do it digitally. This is only done when using DSP volume within ROON. Using fixed volume is actually very crazy, as it should according to logic turn the volume up to max on the BR-20.
Please confirm!
« Reply #727 on: 16 Jul 2025, 12:09 pm »
Hi gr - I may be wrong on that - lets see what others have to say.
james
jbuzas
« Reply #728 on: 16 Jul 2025, 01:09 pm »
I have had bad experiences using Roon to control the volume on my BR-20.   Several times the volume increased without bound, risking damaging the speakers.  I know others have had this issue too.  I don't know if it's been fixed.   I control volume on the BR-20 with the Bryston remote or the knob on the unit when using Roon.
« Reply #729 on: 16 Jul 2025, 01:37 pm »
OK contact Adam and he may be able to help - [email protected]
« Reply #730 on: 22 Aug 2025, 11:38 am »
Nice shot of the colours available.
Jonny S
« Reply #731 on: 5 Oct 2025, 09:32 pm »
I need clarification on hooking up a subwoofer amp to the 2nd set of XLR outputs.
I will have my BR-20 sometime soon. I will have a 4b sst on the main set of XLRs and a Crown XLS2502 amplifier on the 2nd set for subwoofer duty.
The issue is that the Crown will only accept one XLR when used in bridged mode. So normally I would use left. that would be 3 out of the 4 XLR outputs.
What I have read here is that I can not use just one XLR output from this unit. I worry about summing the left and right to a single XLR output for fear of damaging something internal on the BR-20.
What is the proper way to use my Crown amplifier?
« Reply #732 on: 6 Oct 2025, 11:00 am »
Jonny - email Mike on this please - [email protected]
Jonny S
« Reply #733 on: 6 Oct 2025, 07:19 pm »
Thank you James.
I've been dealing with Adam and he is getting me straightened out.
amdan
« Reply #734 on: 18 Oct 2025, 06:52 am »
HI all - does the BR20 require a lot of running in? How many hours before it settles?
« Reply #735 on: 18 Oct 2025, 11:39 am »
Its burned in at the factor so should be OK right out of the box.
james
amdan
« Reply #736 on: 18 Oct 2025, 10:32 pm »
Thanks James. I was surprised to find that the soundstage of the BR20 is much smaller than my previous pre-amp hence the question. The soundstage is between the two speakers and occupies about 2 thirds the width. The only change I have made is swapping pre-amps. Am I missing something?
BTW the amp is a Bryston 14B ST.
« Reply #737 on: 19 Oct 2025, 12:12 am »
That is odd as my BR20 is fine and I am using a BR20 at the Toronto show and the stage is huge :thumb:
Give it some time then and let me know if things change.
best
james
amdan
« Reply #738 on: 19 Oct 2025, 08:06 am »
OK. Will do.
amdan
« Reply #739 on: 19 Oct 2025, 10:17 am »
Found and fixed the problem. Now I have another one!
I tried streaming from my Innuous Zenith 3 to the USB input on the CR-20. After about 40 seconds of play, it stops and Roon says it has lost control of the endpoint. Turning the BR-20 off and on again fixes it for another 30 or so seconds. Any suggestions?
I will try using the streamer in the BR-20 tomorrow and see how that goes.
