Announcing The Bryston BR-20 Preamp/DAC/Streamer
0 Members and 7 Guests are viewing this topic. Read 537123 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Announcing The Bryston BR-20 Preamp/DAC/Streamer
« Reply #700 on: 5 Aug 2024, 03:39 pm »
« Reply #701 on: 30 Aug 2024, 10:50 pm »
« Reply #702 on: 26 Sep 2024, 11:47 am »
amdan
« Reply #703 on: 10 Jan 2025, 11:58 am »
@james tanner - Will there be a new model coming soon? The BR-20 is over 4 years old and am wondering if a new model is being developed.
Clive197
« Reply #704 on: 10 Jan 2025, 01:25 pm »
Unlikely, as the pre-amp is still relatively new for a Bryston. Anyway in my opinion it’s the very best Pre, DAC and streamer on the market. Just saying.😍
« Reply #705 on: 11 Jan 2025, 12:42 pm »
Hi amdan
No plans to replace the BR20.
james
amdan
« Reply #706 on: 14 Jan 2025, 07:38 am »
Thanks James. Could you also please respond to my 4B bridged vs 7B post in this forum? Thank you.
Nitsuave
« Reply #707 on: 17 Jan 2025, 02:32 am »
I wholeheartedly agree!
« Reply #708 on: 6 Feb 2025, 03:32 pm »
VicD
« Reply #709 on: 26 Feb 2025, 10:00 pm »
Anyone know what's new in the BR20 firmware update BR20_2023_10b
bcugk
« Reply #710 on: 26 Feb 2025, 10:05 pm »
Following
« Reply #711 on: 27 Feb 2025, 12:45 pm »
Email Adam on that please.
[email protected]
Clive197
« Reply #712 on: 1 Mar 2025, 03:09 pm »
I’m a little confused. My BR-20 firmware says that it up to date 2022-10-05.
So what is 2023-10b ?
bokko
« Reply #713 on: 1 Mar 2025, 03:42 pm »
It's a firmware update that you do from the BCON side of of BR-20.
I'll contact Adam and see if I need it...
alanford69
« Reply #714 on: 1 Mar 2025, 09:28 pm »
Please share any info you get about this firmware update, others may find it useful.
bokko
« Reply #715 on: 7 Mar 2025, 09:53 pm »
Radio silence.
Never received a response, if I do will post update.
Clive197
« Reply #716 on: 7 Mar 2025, 10:21 pm »
It appears that I have the new firmware when it went to back to PMC to fix a small issue which it turned out was a firmware issue.
bokko
« Reply #717 on: 7 Mar 2025, 10:28 pm »
Like to know what it fixes.
Since getting new one, its been a much better experience vs my first one.
Clive197
« Reply #718 on: 7 Mar 2025, 10:32 pm »
The only difference I’ve noticed is that now when I power up it comes on at the same volume it was when I turned off. It used to come on at the volume it was set when first programmed.
alanford69
« Reply #719 on: 8 Mar 2025, 01:52 pm »
Sounds really like a major leap!
