Announcing The Bryston BR-20 Preamp/DAC/Streamer
John541
Re: Announcing The Bryston BR-20 Preamp/DAC/Streamer
« Reply #620 on: 29 Apr 2023, 09:29 am »
Hi John,
no need to remove the sd card to get a copy of the firmware, we make images available on our support page at support.bryston.com
http://support.bryston.com/downloads/BDP/Manic%20Moose%20Sources%20R4.pdf
This document typically gets updated whenever we update the images.
Chris
Thanks Chris, that's very helpful indeed.
My BR-20 is due to arrive next week.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #621 on: 19 May 2023, 06:18 pm »
« Reply #622 on: 19 May 2023, 07:52 pm »
Hi Folks - got this just now - 2 AWARDS in one day !!!
Sam S
« Reply #623 on: 6 Jun 2023, 07:49 pm »
Hi,
I would like to try DSD256 on a USB SSD on the BR-20 to see how it sounds.
Any suggestions on an SSD drive?
Brand?
Speed? Does it matter?
Does it need to be powered if all I have plugged into the USB ports is the SSD drive?
From the manual the BR-20 will automatically scan the drive and I'll be able to use the built in player to play the files. Accurate?
Any pitfalls I need to be looking for?
Thanks for any information and suggestions.
Sam
Update:
Loaded an album on a SSD.
DSD 4X=Yellow
Source1=Yellow
Lock=Flashing Red
Not sure why Lock light is flashing red.
Seems to be playing in at the proper resolution.
Sounds Fantastic!
Any help appreciated.
Update:
Powered up today and it’s working fine.
« Last Edit: 9 Jun 2023, 02:42 am by Sam S »
jcn3
« Reply #624 on: 8 Jun 2023, 02:39 pm »
Hi,
Brand?
Sam
Update:
DSD 4X=Yellow
Source1=Yellow
Lock=Flashing Red
Sounds Fantastic!
i wasn't able to find the specs, but i recall james saying that the usb port can put out about 500ma -- not very much.  if you're going to connect an ssd, i would power it independently (even though it seems to work without one).  of course, with a thumb drive you could just plug it in and go (it would just be slower, but could handle dsd).
Sam S
« Reply #625 on: 9 Jun 2023, 02:44 am »
Working fine today.
Thanks for the input.
Clive197
« Reply #626 on: 27 Jun 2023, 10:56 am »
Just a quick question. How are we doing with Manic Moose’s replacement?
himitsu
« Reply #627 on: 30 Jun 2023, 01:26 am »
Hi,
I'm trying to get the HDMI board for my BR-20 but the dealer told me still not available, I've been waiting for almost a year, just wondering Bryston won't supply the board only or need to ship the whole unit to Bryston for installation?
« Reply #628 on: 30 Jun 2023, 02:14 am »
Hi
The boards we get from MDS and they tell us end of July.
james
himitsu
« Reply #629 on: 1 Jul 2023, 04:11 am »
Hi
james
Thanks James.
EvanMcC
  • Bryston, Dynaudio & Torus
« Reply #630 on: 25 Sep 2023, 12:35 am »
Hi James,
I can only ever see the first page of these types of postings. Where can I find the full length format?
Evan
« Reply #631 on: 25 Sep 2023, 01:24 am »
Hi Evan - Have to email me and subscribe to the Newsletter.
james
[email protected]
EvanMcC
« Reply #632 on: 25 Sep 2023, 03:28 pm »
Thanks! Will do.
Dan H
« Reply #633 on: 13 Oct 2023, 03:13 pm »
Good day, all,
New user on this forum, and also new to the Bryston world, having recently acquired a previously owned BR-20 and 2.5B/3. As a new user here I'm restricted from searching for answers regarding the BR-20 until my post count reaches 3, so here goes -
I've already updated the BR-20's firmware to version u2022.11a, and S2.45.
Previous owner set up various input names and associations to the IR control buttons. I would like to simply reset all the names back to the factory defaults.
Using the volume knob, I navigate to Global Setting, then to Factory Reset. Next options are "DFLT USER EEPROM", "USB MSD CTR PORT", and "BCON FACTORY RST". These options differ a bit from what is shown in the paper manual. Is "BCON FACTORY RESET" what I need to choose to reset the input names to factory defaults?
Many thanks,
Dan
gwhphoto
« Reply #634 on: 14 Oct 2023, 04:04 pm »
Hi
Newbie here but long time Bryston fan.  Original 4b from 1980s, original 1b pre from early 90s. So far my listening is vinyl and CDs.
But, taking the plunge, I have a brand new 4b3, and will be getting a BR-20 (with phono) in a week!
So, this will be my first digital streamer as well.  I am new to digital and will be using Tidal or Qbozz as opposed to stored music on a hard drive (for now, I ues I will begin burning my CD collection to a drive).
My question is streaming on the BR 20.  I have no ethernet wiring in my house so I will be using high speed internet coupled to WIFI 6 (ax).
I am thinking of getting a WIFI extension node, putting it close to the BR 20, and running an ethernet cable from the node to the BR20.  My wifi nodes are Netgear.
Will this work?  Any suggestions?
I have read that Bryston does not recommend a plug-in usb wifi dongle because it saps power from the usb ports and may create interference?
Would my use of the wifi node about two feet away from the BR20 be a better solution?
 If this will work I will buy the wifi node and have it set up and ready when the BR20 arrives.
Thanks for any help.
Twiga
« Reply #635 on: 15 Oct 2023, 05:59 pm »
Another option would be Netgear Powerline modules. My Bryston equipment is nowhere near any ethernet wiring, so I connected a powerline module to my router and then plugged another one directly (no extension or surge protector) in to an electrical outlet near my Bryston and ran a short ethernet cable from the Bryston to the local powerline connector. It has worked well for me for several years. YMMV
gbaby
« Reply #636 on: 16 Oct 2023, 01:38 pm »
Hi
I, too, do not have an ethernet connection. However, I use a "bridge" connected to my BDP3, and it has never given me a problem. I also have a bridge connected to my BDP2 in my bedroom and likewise, never had a problem.
klao
« Reply #637 on: 19 Oct 2023, 01:17 am »
Hi James,
Has the HT bypass been resolved with the software udpate?
Thanks.
bokko
« Reply #638 on: 19 Oct 2023, 10:20 am »
Home Theater Bypass works fine for me.
Use the RCA 2 input to a Marantz 7012.
« Last Edit: 21 Oct 2023, 02:38 am by bokko »
bokko
« Reply #639 on: 19 Oct 2023, 10:35 am »
Dammit
« Last Edit: 21 Oct 2023, 03:43 am by bokko »
