Questions??? Furutech e-TP80 power conditioning
Sonny
« on: 21 Sep 2020, 04:55 pm »
Hi all, anyone using the Furutech e-TP80 power distribution center and how it is working for you?
I have used a few conditioners/filters throughout my years in this hobby from PS Audio, SurgeX, APC Powervar, Monster, etc., but not too familiar with this.
http://www.furutech.com/2013/01/31/1537/
Of course all the reviews says it's great, but I just want to fix a couple of buzzing components, perhaps a little protection and so forth.
Thoughts are welcome!
T
rollo
  • Rollo Audio Consulting -
Re: Questions??? Furutech e-TP80 power conditioning
« Reply #1 on: 21 Sep 2020, 05:02 pm »
  Sonny maybe locate the cause of the Buzz first. Most likely a grounding issue. Yes Power Conditioners make a difference in reducing incomingAC noise. However do not fix ground issues. Do you separate your Digital from Analog. Dedicated lines ? What components Hum ?
charles
OzarkTom
« Reply #2 on: 21 Sep 2020, 05:05 pm »
I have one of these, and it is great. I doubt if it would solve your buzzing problems though.
Sonny
« Reply #3 on: 21 Sep 2020, 06:21 pm »
charles
It's just the Cary SACD Player...I used a "Cheater" plug and it helped, but still and issue.  It's a buzz, not a hum, actually.
rollo
« Reply #4 on: 21 Sep 2020, 07:58 pm »
  Hey Sonny.So when the CDP is not plugged in no Buzz ? Is CDP plugged into same outlet used for for analog components ?
charles
Sonny
« Reply #5 on: 21 Sep 2020, 08:13 pm »
charles
Charles the buzzing is coming only from the Cary and no other components, well the sub.
Yes, it's plugged into the same as the Phono pre, TT motor, etc.
Sonny
« Reply #6 on: 21 Sep 2020, 10:42 pm »
Thank you!
T
