28b3 - Change LED color - Front Panel removal
0 Members and 1 Guest are viewing this topic. Read 1472 times.
Christo22
« on: 13 Sep 2020, 06:53 pm »
How do you remove the front panel in oder to change the jumper?
I unscrewed the top.
Front panel moves but it seems to be locked somewhere under the amplifier...
Any idea?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 28b3 - Change LED color - Front Panel removal
« Reply #1 on: 13 Sep 2020, 07:08 pm »
Any idea?
Hi - are you sure you have to remove the front panel?  Did you contact Mike at Bryston?
james
Christo22
« Reply #2 on: 13 Sep 2020, 07:21 pm »
Just finished.
Easy stuff.
1 - Put the amplifier on its rear handles on soft material...
2 - Unscrew TOP & BOTTOM panels.
3 - Disconnect the LED from motherboard (FLAT WHITE WIRE).
3 - Unscrew the FRONT Panel from aluminium rail (You'll see it easily).
4 - Move the jumper to BLUE.
5 - Put back together and test.
And... while I was there... I dust it off a little  8)
Just like a brand new one! ;)
« Reply #3 on: 14 Sep 2020, 01:08 am »
Just finished.
Easy stuff.
Congrats !!!
Ola_S
« Reply #4 on: 16 Sep 2020, 06:56 am »
Who in their right mind would voluntarily want to have blue LEDs in his/her listening room? :o Beats me!
Christo22
« Reply #5 on: 16 Sep 2020, 11:09 am »
Funny guy... :roll:
