Any experience with a Tripp-Lite Isoblok?
squidbrand
« on: 9 Sep 2020, 07:54 pm »
My main system has been blessed by what seems to be unusually clean power from the wall, but I haven't had such luck at my computer. 99% of my computer listening is done through headphones (Topping D10 > JDS Atom > Sennheiser 58X) but I'm going to add some powered monitors just for the sake of convenience, and my experience with them so far (with zero power conditioning) has been a very high noise floor.
I'd like to keep my spending to an absolute minimum, since this is a secondary setup within a secondary setup. Anyone had success killing the dirty line noise that makes its way into super cheapo plate amps using a Tripp-Lite Isoblok (the 2-outlet Isobar that sits flush with the wall)?
Phil A
Re: Any experience with a Tripp-Lite Isoblok?
« Reply #1 on: 9 Sep 2020, 11:47 pm »
Don't have direct experience with that model but have Isobar 4 and 6 outlet strips (e.g. https://www.tripplite.com/isobar-4-outlet-surge-protector-6-ft-cord-3300-joules-diagnostic-leds~ISOBAR4ULTRA).  I have one in the office and one in a secondary system (use an old Torus RM-20 in the main system).  Also have a two outlet one of these - https://www.brickwall.com/pages/the-worlds-best-surge-protectors  in a secondary system (plugged my new UHD TV into it).  There's also other devices one can use to use to clean power.  These are just a couple of the examples and I'm sure there are lots more (Yes I use them in various rooms) -
http://www.audioprism.com/quietline.html
https://www.psaudio.com/products/noise-harvester/
I have others as well and make homemade versions of things as well.  As you noted, for a secondary system, one doesn't necessarily want to break the bank.  Some of the things I have in secondary systems as I've found more success with other things in the main system and rotated them there.
Phil A
« Reply #2 on: 9 Sep 2020, 11:47 pm »
PS - Welcome to the forum!
Digitalnomad
« Reply #3 on: 24 Apr 2021, 05:45 pm »
Have used them for years for surge protection and they have worked really well
