GR-Research Speaker Cables build by Rock Ball
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
Re: GR-Research Speaker Cables build by Rock Ball
« Reply #180 on: 23 May 2026, 07:45 pm »
And, another DIY set in the wild.  ESR paper under the heat shrink.  Connectors are Blue Jeans Cable locking bananas.  Easily swapped to something else if needed.  I opted to use 1/4" cotton rope instead of the 1/2" to keep them a bit more manageable.
I'll give a first listen tonight.
Zoe approved!
NIGHTFALL1970
« Reply #181 on: 23 May 2026, 09:09 pm »
Awesome cables!👍
And I love ❤️ Zoe!
Danny Richie
« Reply #182 on: 24 May 2026, 01:52 pm »
Zoe approved!
If you replace those high mass banana plugs with the male tube connector ends you will pick up some added clarity across the board.
pstrisik
« Reply #183 on: 24 May 2026, 03:18 pm »
I am aware.  I may later.  I would lose the flexibility of easily changing the connectors though.  I have the tube connectors you shipped with the Allies.
pstrisik
« Reply #184 on: 11 Jun 2026, 05:53 pm »
I went ahead and replaced the locking bananas with the tube connectors.  Ta da!\
I notice that the male tube connectors make decent contact with traditional binding posts.  They just don't go all the way in.  What do you think about cutting the appropriate amount of the tip off the male connector to make a better fit with binding posts?  Not quite a complete TC set, but lower mass than the locking plugs.  I'm not going to go as far as replacing the binding posts on the amps.
Danny Richie
« Reply #185 on: 16 Jun 2026, 06:48 pm »
The problem is that the spring mechanism for latching onto the male tube connector end is in the female end. A binding post has no way of really holding it other than a friction fit.
pstrisik
« Reply #186 on: 16 Jun 2026, 07:11 pm »
Ahh, I see, thanks.  I'll make sure it is tight enough to hold at my amps when the male ends come tomorrow.
