(Sold) Akitika GT-102 Stereo Amplifier Factory Built for sale (sold)
0 Members and 1 Guest are viewing this topic. Read 1297 times.
Boozebottler
Akitika GT-102 amplifier, 50 watts per channel. This amplifier was assembled at the factory. Four softer feet (Herbie's Audio Lab) are attached, also 3M damping sheets. Both are easily removed if desired. Used, excellent condition, second owner. Includes original box and original feet.shipping and PayPal fees are buyers responsibly.
Information: https://www.akitika.com/GT102.html
Stereophile review, highly recommended:  https://www.stereophile.com/content/akitika-gt-102-power-amplifier   Specs: Output Power: greater than 50 Watts per channel into 8 Ohms Small Signal Bandwidth: typically wider than 5 Hz to 100 kHz at -3 dB points Slew Rate (typical) 14 Volts/microsecond Damping Factor @ 1 kHz wrt 8 Ohms: >80 Signal to Noise Ratio: typically 136 dB below 50 Watts into 8 Ohms, A-weighted, referred to a shorted input. Harmonic Distortion: typically 0.003% at 50 Watts into 8 Ohms at 1 kHz. Clipping occurs at a bit more than 60 Watts into 8 Ohms at 1 kHz. Intermodulation Distortion: 0.004% typical, SMPTE 4:1, 60 Hz, 7 kHz Separation: >90 dB at 1 kHz, >70 dB at 10 kHz Input Impedance: 51 K Ohms Sensitivity: 1 Volt RMS input produces 20.59 Volts RMS output Dimensions: 15” Wide x 10” Deep x 4.5” Height (includes height of the feet) Input Power: 120 VAC 60 Hz, IEC connector (power cord supplied) Input Power Fuse Rating and type: medium acting 3 Amps or 3.15 Amps, 5x20 mm 220-240 Volt operation also possible with the V240 kit, which uses a 1.5 Amp fuse Weight: 15.5 lbs Shipping Weight: 19 lbs
« Last Edit: 15 Sep 2020, 02:27 am by Boozebottler »
tdinut
  • Joe aka Joeinid on other forums.
    • Audioshark Forum
Re: Akitika GT-102 Stereo Amplifier Factory Built for sale $340
« Reply #1 on: 1 Sep 2020, 12:24 am »
This is a great little amp.
Good luck with your sale.
Boozebottler
« Reply #2 on: 1 Sep 2020, 12:29 am »
Thank you!
tdinut
    • Audioshark Forum
Boozebottler
Price lowered!
