What sort of connector from power supply box to signal box?
0 Members and 1 Guest are viewing this topic. Read 2084 times.
BillEpstein
I've had the 2 Bugle (Hammond) boxes sitting open and hardwired together but now it's time to make them pretty. Since it's just 15VDC will ordinary RCA's handle the (+) and (-) or something more specialised needed?
BradJudy
« Reply #1 on: 2 Mar 2005, 02:00 pm »
RCAs could handle it fine, but I don't like using them for power because sooner or later you make a mistake wiring things up and could damage components.  I like using the standard DC power jacks/plugs so you always know what you're dealing with.
JoshK
« Reply #2 on: 2 Mar 2005, 03:18 pm »
Do you just have three wires?  +, - and ground?  Used an XLR imo, they even make 5 pin XLRs now if you were to have more voltages.  For my tube preamp, I am moving the iron to a seperate box and using a 6 pin Amphenol connector but that is because some are high voltage and quite a few secondaries.  Amphenol connector that I have is a bit spendy ($25 & $8, m/f).  There is also neutrik Powercon which are killer power connectors and made for such a job.
BillEpstein
Will these work?
« Reply #3 on: 2 Mar 2005, 09:53 pm »
All the Powercon I found are 3 pole. It seems the Bugle would require 4 pole. These are Speakercon.
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=092-052#
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=092-050&DID=7
"For speakers and amp connections," it says.
JoshK
« Reply #4 on: 2 Mar 2005, 10:01 pm »
I was thinking of XLR for this app.  They come in 3 pin (what we are use to) 4pin and 5 pin.
markertek
BradJudy
« Reply #5 on: 2 Mar 2005, 10:05 pm »
The Bugle should only require two poles for power.
hagtech
« Reply #6 on: 3 Mar 2005, 02:29 am »
You only need 3 wires for Bugle power.  That's XLR, or twisted pair plus shield, or two dc jacks, or anything with 3 separate connections.
jh :)
