Connecting Subwoofer to Kitoki?
flyingelephant
« on: 12 Aug 2020, 07:52 pm »
Hello,
I'm about to buy some Omega speakers, and Louis from Omega gave an enthusiastic recommendation for the Kitoki as a great match for his speakers.
I have a powered subwoofer - can I connect both the Omegas and the sub to the Kitoki?
If so - how?
Many thanks!
RDavidson
Re: Connecting Subwoofer to Kitoki?
« Reply #1 on: 12 Aug 2020, 08:23 pm »
I'm sure there may be converter boxes and things of that nature, but your sub would otherwise need speaker level inputs. Not all subs have these. Alternatively, you could also see if Wolf Ear could put a line level output on the Kitoki. That may be much easier said than done, however. What subwoofer do you have?
flyingelephant
« Reply #2 on: 12 Aug 2020, 08:51 pm »
Hi RDavidson - thanks for your reply.
The sub is a RSL Speedwoofer 10.
opnly bafld
« Reply #3 on: 6 Sep 2020, 02:33 am »
Speaker level inputs in parallel with the Omegas.
