0 Members and 1 Guest are viewing this topic. Read 5356 times.
From the posts I see that some VMPS VIP's have already received the midwoofer upgrade kit. I am trying everything to get up on the pecking order here, but I must be really low as I have not received my upgrade package yet. I am so low that I don't even get PM's answered from a well known dealer and a frequent poster here. What can I do to upgrade my VMPS stature? If I promise to post everyday saying VMPS makes the best speakers in its class, would I move up in the standing? Is ther ...
Marbles, how long were the braces you used? I'll pick up some 1x1 pieces of oak to brace with from home depot. I'll just have them cut to whatever length you found was the best fit....
Actually Woodsyi I think you've been bumped on this lot but you'll be getting one of the first ones of the next shipment in May. Pretty funny huh:)
Marbles,Why would you turn down your sub to 35 from (presumably higher frequency)? If the woofers as a tandem are going to cover higher frequency range, I would think it would make sense to raise the high pass frequency? What I don't understand about the whole TRT cap adjustment is why it is necessary to change the x-over value between the ribbons. I am sure there is reason why tweet and mids x-over has to be reconfigured when woofers go higher. All I am hoping for is that this upgrade will give better definition in the critical 200-300 Hz area where male voice dominate. Since I actively bi (tri with sub) amp, I plan to raise the highpass frequency of the ribbons to around 270 Hz to get out away from the woofers. Hopefully this will reduce the smear. I may still cross the woofers at 300 Hz lowpass . I plan to keep the highpass of the woofers at 50Hz. This way the woofers on RM40 doesn't have to deal with long excursions and I hope this means that they can stay fast and punchy. A larger or (two in the future?) can deal with below 50 Hz. Would MLS cabinet benefit from bracing as welll? I don't suppose it would hurt ...
