LPS 205, 212 shipping around last week of August
0 Members and 1 Guest are viewing this topic. Read 3764 times.
rustydoglim
« on: 7 Aug 2020, 02:36 am »
Low power devices such as DAC, streamer, CD player, media server, and digital music player are susceptible to AC noise from switching mode power adapter. However, not any linear power supply will suffice as a replacement for the switching mode power supply.
NuPrime LPS-205 & LPS-212 linear power supplies incorporated a fully balanced El-frame transformer architecture design that is less susceptibility to core saturation from DC offset.
The following features make LPS-205 or LPS-212 a Hi-Fi power supply with clean and stable output power designed for audiophiles:
•   Low noise MOSFET
•   EMI filter
•   Soft start & fanless design
•   Full transformer epoxy resin package to avoid vibration interference
•   Low dropout linear output
•   Overvoltage protection
•   Overcurrent protection
•   Over-temperature protection
•   Lightning protection
•   Large capacitance output higher than 35,000 uF)
LPS 205 Specifications
•   LED status display for Standby, In-Use, and Protection state
•   Input: 230VAC or 115VAC 50/60Hz (with voltage selector)
•   Output: Two sets of DC 5V/2A isolated and independent outputs (Zone 1 & Zone 2)
•   Output connectors: Two sets of 5.5 X 2.1 female socket and two sets of USB-A female socket
•   Total power 28W
•   Dimension:155 mm X 115 mm X 60 mm
•   Weight:1.6 KG
LPS 212 Specifications
•   Output: DC 12V/2A and DC 12V/1A outputs
•   Output connectors: Two 5.5 X 2.1 female sockets
•   Total power: 36W
•   Dimension: 155 mm X 115 mm X 60 mm
•   Weight: 1.6 KG
rustydoglim
Re: LPS 205, 212 shipping around last week of August
« Reply #1 on: 7 Aug 2020, 02:36 am »
Pricing to be announced next week.
Samoyed
« Reply #2 on: 7 Aug 2020, 12:56 pm »
Promising products, so I hope they are well priced.
mresseguie
« Reply #3 on: 7 Aug 2020, 04:09 pm »
Cool!
 :popcorn: :popcorn: :popcorn:
PBN94F
    • Esprit-Racing
« Reply #4 on: 12 Aug 2020, 02:20 pm »
Nice for the WR-1  8)
rustydoglim
« Reply #5 on: 13 Aug 2020, 04:34 am »
$329 MSRP for LPS 205 or LPS 212.
PBN94F
    • Esprit-Racing
« Reply #6 on: 16 Oct 2020, 06:58 am »
399€ in France  :roll: :roll: :roll:
Westerwälder
« Reply #7 on: 16 Oct 2020, 02:03 pm »
399,-€ in Germany
rustydoglim
« Reply #8 on: 19 Oct 2020, 12:47 am »
We raised the price for USD too. The shipping cost is crazy high, which is absorbed by importers.
Amal
« Reply #9 on: 6 Nov 2020, 05:21 pm »
Hello Jason
I know it is a difficult question to answer but is it equivalent in terms of performance compared to Sbooster, Teddy Pardo, Paul Hynes Sr4t or even Farad Super3?
Regards
Nicolas
rustydoglim
« Reply #10 on: 8 Nov 2020, 04:23 am »
It is easy to answer - we don't compare and have no idea how they design their product, or any of them actually designed their products. I can only tell you what we have done.
Amal
« Reply #11 on: 9 Nov 2020, 10:10 pm »
So for you it is designed to give the lowest noise and the less tension deviation under load.
This what does a good lpsu, right?
rustydoglim
« Reply #12 on: 10 Nov 2020, 10:52 pm »
A good LPS is the selection of low noise transformer (extensive contacts and experience in the power supply industry), filter design, protection circuits, low noise power and ground design.
Amal
« Reply #13 on: 13 Nov 2020, 07:51 pm »
Thank you
