SS 9.5 versus SS 8, open back
0 Members and 1 Guest are viewing this topic. Read 1298 times.
Jeff in the D
« on: 1 Aug 2020, 07:45 pm »
Does anyone here know if the open mid or back on the SS 9.5 is the same as what the SS 8 has? On the SS 8 there are several options available but it starts with there being an area behind the Raal and the Accuton that is open. The amount of stuffing used is left up to you. You choose which cover to use, either the grill or the solid one. Using the grill, varying the amount of stuffing, the physical distance from the rear wall , all affecting the ambiance.
Or, use the solid cover and eliminate all of those effects.
Same for the SS 9.5?
Jeff
ddps
  • Salk SS 9.5 / McIntosh MA8900 / Auralic Altair
Re: SS 9.5 versus SS 8, open back
« Reply #1 on: 1 Aug 2020, 09:02 pm »
Jeff in the D
« Reply #2 on: 1 Aug 2020, 10:33 pm »
Thanks for the confirmation.
Jeff
