Spikes or rubber feet on sub
0 Members and 1 Guest are viewing this topic. Read 2346 times.
Creative cut designs
« on: 31 Jul 2020, 09:36 pm »
How important is it for either spikes or rubber feet on a subwoofer?
Hobbsmeerkat
Re: Spikes or rubber feet on sub
« Reply #1 on: 31 Jul 2020, 09:44 pm »
It depends on the type of floor of the room it will be used in.
Spikes for solid, concrete,  ground-level floors, and dampening rubber for wood-frame and suspended floors.
But you can use either option group level concrete tbh. Although, if a sub constantly causes things to rattle in your room/house, dampening will likely be your best bet.
« Reply #2 on: 31 Jul 2020, 10:41 pm »
Thanks much !
Rock Ball
« Reply #3 on: 4 Aug 2020, 04:01 pm »
I'm experimenting with tennis balls.  My listening room is above a two-car garage so the floor is wood.
First, I had the subs sitting on the carpet.  Next, I tried them with spikes on.  Finally, I tried the tennis balls.  There are 15 under each sub.
Because all three drivers face forward, the weight of the magnets make the center of gravity more towards the back.  I placed the middle row of 5 balls closer to the back.
I was surprised at how little the subs wobble when you push on them.  They do not move around easily at all. My wife says that the bass is not as loud in the rest of the house now.
I am happy with the performance that I get from these, so now I will make a black cloth skirt to hide the bright yellow balls even though my wife likes the look of them the way they are.
Hobbsmeerkat
« Reply #4 on: 4 Aug 2020, 04:13 pm »
That's actually a really cleaver idea!
Rock Ball
« Reply #5 on: 4 Aug 2020, 07:24 pm »
I got the tennis ball idea from YouTubers who were using them to build drum kit isolation platforms.
Another option might be black handballs or racquetballs.  I don't know if they are sturdier or not, but I would prefer the black over bright yellow.
« Reply #6 on: 5 Aug 2020, 12:42 am »
That's interesting
rajacat
  • Washington State
« Reply #7 on: 5 Aug 2020, 12:50 am »
Danny Richie
« Reply #8 on: 6 Aug 2020, 01:51 pm »
Does your brother know that you got into his tennis balls?
Rule of thumb on this stuff is that if the floor is lossy (suspended floor) then use a damper.
If the floor is a solid slab of concrete then spike it to the floor.
GeAllan70
« Reply #9 on: 6 Aug 2020, 02:50 pm »
then PENN are ok... i go for the Wilson US Open Extra Duty myself...  :lol:
Rock Ball
« Reply #10 on: 6 Aug 2020, 04:09 pm »
:lol:
This was after the lockdown started, so couldn't go steal some from him.  I still haven't heard his NX-Oticas.
