BR-4 Instructions
0 Members and 1 Guest are viewing this topic. Read 4169 times.
gberger
  • Check 6
BR-4 Instructions
« on: 28 Jul 2020, 02:29 am »
Is there a manual or set of instruction sheets to go with the new BR-4 remote control?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BR-4 Instructions
« Reply #1 on: 28 Jul 2020, 11:26 am »
Not sure on that - Mike would know - [email protected]
Here's what I have:
Here's some BR4 Firmware Notes:
---------------------- Reset to factory default --------------------------
Press 'CODE' for 5 seconds, until LED blinks.
Release 'CODE' button.
Press '795', LED will blink 4 times.
;---------------------- Volume Function -----------------------------------
By default, the volume buttons control the programmed pre-amp even when that mode is not selected.
To use the BDA3.14 volume control:
Press '717', LED will blink 2 times.
Press '750', LED will blink 2 times
To use the pre-amp volume control:
Press '751', LED will blink 2 times
---------------------- Device codes --------------------------------------
Device codes for Volume/Mute functions
710 0000 Not assigned
711 0001 SP1.7/SP2
712 0010 B100/BP16/BP17
713 0011 Not assigned
714 0100 Not assigned
715 0101 BCD1, BCD3
716 0110 BDA1, BDA2 *** NO VOLUME CONTROL ***
717 0111 BDA3, uses device ID 6
718 1000 Not assigned
719 1001 BDP3, uses device ID 9
720 1010 Not assigned
721 1011 BP25/BP26
722 1100 B60/BP6
723 1101 Not assigned
724 1110 Not assigned
725 1111 Not assigned
750 - Select D/A to use the BDA3.14 volume control.
Select Preamp to use the preamp volume control.
751 - Preamp volume control is used in either D/A or Preamp mode.
james
gberger
  • Check 6
« Reply #2 on: 28 Jul 2020, 01:16 pm »
James
Wow!    Thank You!
I bought two of them several months ago for the volume on my BP17C, and to possibly control my BCD -3. I received another one with a B60R for my Grandson's system.
Thanks Again,
George
bokko
« Reply #3 on: 29 Jul 2020, 02:15 pm »
Good Day:
I would also like to see the instructions and a chart of what the remote is compatible with.
Similar to way BR2 is presented on website.
lloydVIII
« Reply #4 on: 16 Dec 2024, 05:56 pm »
Hi, what could be the problem if the device code for the BDP-3 is not working on my BR-4?
I tried it a hundred times. If I try to program the bdp-3 with code 719 there is no blinking two times, light just goes out instantly. It doesn't accept the code.
Is there a older version of the BR-4 which doesnt "know" the BDP-3 and which I might have? It came along with a demo device I bought ...
Thanks for any help!
Alois
« Reply #5 on: 16 Dec 2024, 08:54 pm »
To reset the BR4 to factory defaults, press the CODE button for 5 seconds until the status LED blinks, release the CODE button, then enter 795 on the keypad  The status LED will blink 4 times to let you know it was successful.
To control the BDA3.14, please press the Digital button to set it to the correct mode.
lloydVIII
« Reply #6 on: 2 Jan 2025, 03:38 pm »
Thank you for your reply, Mr. Tanner.
I tried that, but with no effect. I can progam my BR4 with the codes of the BDA-3 and the BP-26 and it works perfectly. But still not with the BDP-3. No blinking if I enter code 719, bdp3 cannot be controlled.
Happy New Year!
BeeJay
« Reply #7 on: 3 Jan 2025, 08:39 pm »
Greetings, Lloyd.
Have you ensured your BDP-3 is set to Device 6?  See instructions I received in 2023 from Adam Tanner following.
Pressing the up arrow and left arrow in quick succession brings up a menu that allows for the following adjustments: Display Brightness: 1-4 Display
Timeout: 10 seconds to never.
IR Address: 1-7 (dont touch this)
Device ID: 6 or 9
If yours is set to 9 use the down arrow to change it to 6.
Just let the screen timeout and then your BR2 or BR4 should turn the power off - be careful as it will turn off the BDP3 and any BDA3 in the room at same time.
Also, when you press 'Digital'+Power on or off does your BDP and BDA turn on or off?
Barry
lloydVIII
« Reply #8 on: 6 Jan 2025, 09:01 am »
Device ID: 6 or 9
Hi Barry, thank you for your reply. It's nice to see that there is always one more thing one can try.
I have found the menu. But it turns out that the adjustments of 'Device ID' are not '6' or '9'. Strangely I can chose between '=' and '2'. Maybe I have a different system version?
Anyway, I tried both options. None of them changed the behaviour of the remote control. Still not able to program it with code 719, still not working with the bdp-3.
When I press 'digital' and 'power' the BDA-3 reacts normal and turns on or off. The bdp-3 doesn't react in any way.
Best, Alois
BeeJay
« Reply #9 on: 6 Jan 2025, 04:55 pm »
Hello, again, Alois (sorry about my wrong name guess).
Have you checked your system firmware value?  Are you connected to the internet (either Ethernet or WiFi)?
I checked the manual and = or 2 donˋt appear to be valid Devce Setting options.  Do you have the BDP-3 Manual?  If not, let me know and Iˋll get you a link to one.
Barry
BeeJay
« Reply #10 on: 6 Jan 2025, 05:00 pm »
Time Offset adjusted.
B
BeeJay
« Reply #11 on: 6 Jan 2025, 06:13 pm »
BTW, Alois, make sure the ÌR Addressˋ is set at 1 and not adjusted in the future.
Barry
lloydVIII
« Reply #12 on: 6 Jan 2025, 06:56 pm »
Hi Barry,
I checked the manual. You are right, nothing mentioned about = and 2 there. The firmware was already up to date but I re-updated anyway, with no effect.
I guess it can be presumed that both phenomenons - the remote not working and the unusual menu options - are connected. I looked into the options of the web interface if I can find anything that could change the bdp-3-settings, but no success either.
I have one option left: Reset to factory settings and update again. But before I do that I will try contact the local Bryston distrubtor (from whom I bought the device which was used as a demo). Maybe they have an idea whats going on. They said they used it with a remote.
Thank you,
Alois
BeeJay
« Reply #13 on: 6 Jan 2025, 08:30 pm »
Best of luck.
Barry
