Basic Khartago question
Lynxo
« on: 27 Jul 2020, 07:21 pm »
Hi,
Does the basic Khartago stereo do Class A for first 7-8W or that is only on the Stratos?
What do you gain for adding another 60,000uF caps?
Re: Basic Khartago question
« Reply #1 on: 27 Jul 2020, 08:12 pm »
Klaus will adjust this bias setting according your speaker sensitivity.
Bass omph etc
Lynxo
« Reply #2 on: 28 Jul 2020, 01:56 am »
Any ideas sound difference between basic and SE version?
« Reply #3 on: 28 Jul 2020, 02:05 am »
Unfortunately no but there are plenty of members that own the Khartago.
klaus@odyssey
« Reply #4 on: 28 Jul 2020, 08:11 am »
Actually,  I'll set up the amps bias according to the tonal signature of the speakers....looking for the combo to have ideal:
emotions.....goosebumps
threedimensionality
non-fatiguing, natural tonality.
Of course this requires a huge amount of experience and feedback with speaker combinations.....well,  after decades and 7000 + amps made,  I guess I covered most of them.
I just cannot state emphatically over and over and over again as to how important the correct bias setting is for optimum sound quality....HUGE !!!!
topside3
« Reply #5 on: 28 Jan 2022, 12:32 am »
Klaus, what bias setting do you recommend for Focal Sopra 2 (Kismet monos)
