0 Members and 1 Guest are viewing this topic. Read 2379 times.
I kinda like bringing stuff back from the dead... Last month I rebuilt an impact wrench from the 1950's, and then a heavy duty Hitachi corded drill that needed a switch and brushes. All stuff that cost about $15-20 (before spending more than that in parts).
... The repair will leave the bevel up in the suminigashi too which creates a feeling of drag while cutting...And this is a real concern. I don't know if the SG2 core goes all the way up the blade, or if it's an insert upon forging. It may be the thinning suminigashi exposes-- more of the soft cladding. The hope is that thinning could remove 1/4" of cladding to expose more SG2.Shun has a pretty good warranty and may replace it. If they don't they will probably "repair" it. A coworker of mine went that route. If it was VG-10 I'd probably throw it away but those SG-2 & R2 knives are spendy! This the wisest choice, and what I should do.My approach is to use a Sharpie to draw a new bevel to guide my grinding. Yep, I've seen this done, it's easy, and it works.
