Hi Michael, you would use just one channel of the amp. Perhaps in the Squeezebox there is an option to mix both channels to mono? Then connect just one channel to the amp.
There are dayton bluetooth amps if I remember that can do summing to mono, I was considering a similar thing to convert a center to a bluetooth boombox.
With a 7% discount, I'm buying a simple mono integrated 240w amp.
