Crossover point for Omega SAMs
0 Members and 1 Guest are viewing this topic. Read 1645 times.
NoDisco
« on: 12 Jul 2020, 06:20 pm »
I have a pair of stereo subs...any idea of a good crossover freq?
justforfun
Re: Crossover point for Omega SAMs
« Reply #1 on: 13 Jul 2020, 12:52 pm »
I have Modern CAMs and my sub is set to 80Hz. Your SAMs should have a deeper base with their larger cabinets but 80 may be a good starting point for you. Good luck dialing them in!!
seikosha
« Reply #2 on: 13 Jul 2020, 02:53 pm »
There is no one best setting.  All rooms are different and the best settings can be different in each room, even with the same equipment.  Just experiment and pick the setting that sounds best to you.
NoDisco
« Reply #3 on: 13 Jul 2020, 10:16 pm »
I’m running about 80 too now. I’m trying to push the subs further out of the way, and this seems about right, but may crossover even lower. Subs are close to the wall, speakers are three feet or more into the room.
