SOLD: Denon AVR-5308CI Multichannel/Stereo AV Receiver
0 Members and 1 Guest are viewing this topic. Read 956 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
Denon AVR-5308CI Multichannel/Stereo AV Receiver  $985.00
Denon pulled out all the stops when they created their flagship AVR-5308CI. This sophisticated receiver turbocharges your high-definition home theater with a host of advanced audio and video features. For starters, it teams up 150 watts per channel of precision, high-current power with THX® Ultra2 processing. This potent combination guarantees intense, high-impact surround sound from all your entertainment sources. Plus, you get Dolby® True HD and DTS-HD™ Master Audio decoding to provide superior surround sound with compatible Blu-ray players and discs.
Outstanding picture quality from every video source
The '5308CI will accept as many as six high-definition digital video signals at resolutions up to 1080p via its HDMI inputs. This lets you hook up high-res sources such as HD DVD and Blu-ray disc players, an HDTV tuner, and a high-end DVD player like Denon's DVD-5910CI, and easily switch among them. Two HDMI outputs mean you can route your high-def video signals to more than one HDTV or projector.
Denon also equipped the '5308CI with the Silicon Optix Realta™ HQV chip — a state-of-the-art video processor usually found only in professional video equipment. It incorporates broadcast-quality video deinterlacing and 1080p scaling for improved detail and smoother playback from all of your video gear, whether connected via HDMI or analog inputs.
Wi-Fi® connectivity and HD Radio
This receiver gives you convenient wireless access to digital music files and JPEG photos stored on your PC, using your Wi-Fi or Ethernet home computer network. It also lets you tap into the world of Internet Radio via a broadband Internet connection. The built-in HD Radio tuner lets you listen to the free, over-the-air digital programming that many AM and FM stations now broadcast. Plus, you get front- and rear-panel USB ports to plug in a compatible MP3 player, hard disk drive, or USB flash drive loaded with your favorite tunes.
Power and Processing:
150 watts x 7 into 8 ohms (20-20,000 Hz) at 0.05% THD
THX Ultra2 certification for exceptionally accurate surround sound
THX Surround EX, Dolby® TrueHD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio, Dolby® Digital EX, DTS-ES™, Pro Logic® IIx, and DTS Neo:6 decoding, and Dolby Headphone processing
Silicon Optix Realta HQV video processing and scaling
Audyssey Laboratories' MultEQ XT eight-point auto setup and room calibration system (microphone included)
four-room/four-source output includes:
with powered and line-level stereo audio output for 2nd or 3rd room (using powered 2nd or 3rd room stereo output allows 5.1 home theater in main room)
digital audio output for 4th room via optical digital out (available only with sources input through an optical or coaxial digital connection to receiver)
toroidal power transformer
Digital Music Options:
iPod®/iPhone® connection through optional Denon Dock
built-in Wi-Fi for music and JPEG streaming from a PC network
XM Satellite Radio Ready with decoding for XM's HD Surround channels (requires XM subscription and optional XM tuner kit)
built-in HD Radio tuner with multi-casting reception
Compressed Audio Restorer for better sound with compressed music sources
line-level or powered stereo audio output with volume, balance, and tone control for 3rd room
discrete 2nd room theater output (optical digital)
conversion of optical or coaxial digital signals to analog audio output for 2nd and 3rd rooms (PCM signals only)
Audio Performance Features:
Advanced AL24 Processing for all channels
HDCD decoding
16 Burr-Brown PCM1796 192kHz/24-bit digital-to-analog converters
DDSC-Digital construction
Dolby Headphone mode for surround sound with standard stereo headphones
Connections:
1080p-compatible HDMI digital video switching (6 in, 2 out)
analog-to-HDMI video upconversion (up to 1080p output via HDMI)
HDMI version 1.3a
component video switching: 6 in (including 1 BNC), 2 out (including 1 BNC)
component video conversion (composite to S-video, or composite and S-video to component) for main room and 2nd room
composite, S-video, and component video output for 2nd room (composite video output for 3rd room)
digital audio inputs: 5 optical (including 1 front-panel), 4 coaxial, 2 BNC
digital audio outputs: 4 optical
8 audio/video inputs, including:
1 front-panel input with composite and S-video
7 rear-panel inputs with composite and S-video
2 audio-only inputs (including phono)
7.1-channel analog audio preamp input
9.3-channel analog audio output
front and rear USB ports for audio playback from USB flash drives, hard disk drives, and portable USB music players
two RS-232C ports (for control via PC or automated system)
Denon Link jack (3rd edition)
Ethernet port for music streaming from a PC network, Internet Radio capability (broadband connection required), and control via a PC
detachable power cord
1 set of main speaker outputs
back surround speaker channels re-assignable for bi-amping front left and right speaker
Precision auto setup tailors sound to your room
Denon also included Audyssey MultEQ® XT, a sophisticated auto-calibration system that helps you get the most accurate home theater sound possible. The '5308CI uses the supplied microphone to analyze sound from up to eight different listening positions, then automatically adjusts level, equalization, and delay settings for each of your speakers. You get precise response across a wide listening area instead of just a single "sweet spot," so everyone in the room can enjoy balanced home theater sound.
Multi-room flexibility
This receiver's multi-source, multi-room output gives you flexible entertainment options throughout your home. You can enjoy a surround sound movie in your main room while a housemate watches a different video source in a second room, and another housemate listens to stereo music in a third. You can even route digital audio signals to a fourth room for playback with an additional receiver.
Top-notch construction for detailed sound
The '5308CI treats your digital music sources right with 16 high-quality Burr-Brown digital-to-analog converters, and a Pure Direct mode that lets you switch off the video circuits and display panel for greater sonic purity. This receiver's rock-solid construction includes an anti-resonant chassis and an oversized power supply with a toroidal transformer. This beefy build ensures pristine audio and video performance at all times.
« Last Edit: 10 Dec 2020, 10:18 am by Bostown »
Bostown
Re: FS: Denon AVR-5308CI Multichannel/Stereo AV Receiver
« Reply #1 on: 24 Sep 2020, 06:54 am »
relisted...
« Last Edit: 28 Oct 2020, 08:57 pm by Bostown »
