My friend has that Kitchen Aid... much quieter than my Gaggia, and probably just as well built. It does occupy quite a bit of cabinet space.
I use the older KitchenAid burr grinder the "Contour" model which I guess they don't make anymore. The thing is a freaking beast:https://www.amazon.com/KitchenAid-KCG0702CS-Coffee-Grinder-Contour/dp/B00XPRQW2A?th=1
The KitchenAid is also my grinder. A very durable product, not the best espresso grinder, but great at other grinds.
Switched to an OXO grinder last winter, I couldn't be happier
I have a Baratza Encore for french press...I really don't like it. It grinds well, but its noisy, slow and makes a mess.I have a Eureka Silenzio for espresso and its been great, thinking of trying a Eureka Filtro to replace the Baratza.
Not sure if Baratza has been mentioned but they are very highly recommended by coffee professionals, roasters, baristas , etc...for a home grinder. You can always buy parts for them , even for their discontinued models. I have a 15 year old Maestro with a separate weighing unit called the Esato which connects to the grinder and allows me to auto grind a precise amount. I've replaced the burrs with better ones from Baratza and other small parts that wear out.Many of their current offerings have the weighing/scale feature built in if that's important.Some of the grinders are more "geared" towards coffee and some more towards espresso.Even their base model, the Encore is an excellent unit.They are an Italian company but have a service center in the Pacific Northwest...I think Seattle.https://www.baratza.com/landing/product/grinders
I have a Baratza Encore for french press...I really don't like it. It grinds well, but its noisy, slow and makes a mess..
