cymbal amps
0 Members and 1 Guest are viewing this topic. Read 1287 times.
JoshK
cymbal amps
« on: 25 Feb 2005, 12:24 am »
Hey Jim,
Got a question-A for you.   A recent thread got me browsing your site yet again.  I must have missed this earlier but your cymbal amp description mentions they have a full differential input, does this mean they can be built to take an XLR (balanced) input with the normal CMR benefits?
Mahalo,
hagtech
cymbal amps
« Reply #1 on: 25 Feb 2005, 03:37 am »
Yes they can!  You can run fully balanced signals on the input.  Connect "+" to R15 and "-" to R39.  Leave out the ground lift switch.  Both polarities are then terminated by 47k ohm (R25, R30), which you could change to anything you want.
It's a great way to do the input/driver stage.  The current source in the tail forces a much improved ac balance, you can run XLR or RCA, you can float the whole thing dc-wise a volt or so in either direction (for long runs without ground loops).  And if you use a low rp tube (6H30, 5687, ECC99), it can directly drive most output stages.  It's just so simple I don't know why more amplifiers use it.
jh :)
