PI Audio fully custom UberBuss
dpatters
« on: 14 Jun 2020, 10:52 am »
This is my custom build from Dave. It is combination UberBuss and DigiBuss
Some highlights:
The Uber section is a 3 stage power filter with no components that will degrade SQ. This feeds a power factor correction section utilizing specially selected X type capacitors. The receptacles are modified Pass and Seymour 5632A. The Digi section is fed by the  Uber. The Digi utilizes an LCR network to trap noise from 500 Hz up to light. This design is basically a back EMF noise trap rather than an incoming noise filter.
Custom burl veneer to match my Vapor Joule Blacks.
My audio components including power amps are plugged into Uber. Video components plugged into Digi. The system is dead quiet and shows no loss of dynamics.
Thanks Dave! A wonderful addition to my system.
Don P
