0 Members and 1 Guest are viewing this topic. Read 4918 times.
Most tube amp designs can be turned on for short periods without speakers connected; not sure about the Cayin. When a tube amp is connected without the speakers or a resistor of adequate value the output transformer starts to short circuit and warmup, what first heats up is the wiring of the windings, which can harm the protective varnish of the winding wiring. That was not a good recommendation them give to you.
I should have been clearer and not suggested running without a load is recommended - my bad. In a stable amp with no signal applied, the amp should be fine for short periods. That said, it is recommended practice and safest to have a dummy load or, of course, speakers attached to the speaker terminals. Mistakes and accidents happen. Play it safe. I do.
running without a loadNow I also was in doubt, maybe E55L2 that makes audio transformers for over 20 years can enlighten us?
At the moment you switch off a amplifier you shut off the mains transformer. Physics tells you that the abrubt switch off will induce a voltage spike. If the amplifier is disigned correctly you don't get a "pop" on your speaker. Not every amplifier has enough filtering to filter out this spikeIs the mains transformer a toroid?btw If you switch on without a load or have signal on the amplifier without a load, a penthode amplifier can cause damage to your output transforer, ultra-linear maybe a problem, triode output probably no harm for your outputtransformer
I'm not sure. So from that image you posted what could be the culprit? The pop is coming from both speakers. So it can't be something faulty from one side as chances both sides having similar bad parts is low probability. One guy says something is getting out of the power supply and getting into the audio circuits.
Dealer got back to me saying it could be a faulty resistor which is responsible for discharging the capacitors or even faulty capacitors discharging abnormally. Does that make sense to you guys?
