I'll wager there are plenty of amps (mostly used) that will fit your budget. I just had a conversation with another AC member who owns two Schiit Aegir amps. He's running them mono, which is over your budget, but you could try one first to hear if it fits your system. Schiit has a 15-day return policy. I have never heard the Aegir, so I can't comment on it's sound.Have you checked Canuck Audiomart to see what is available nearby?Michael
Todays integrated designs are heads and heels above what they were. Separates will offer many options which frankly just may be not worth it. It is about the power supply and or supplies. Consider both. Hybrid, SS or tubed. charles
Bryston has come a long way since the 3B-ST. Not a bad amp, but not as smooth and refined as newer offerings from them and others.
I always recommend shopping for speakers first, that is speakers for the given room and your tastes. In that regard recommend reading Floyd Toole's "Sound Reproduction" 3rd edition, the consummate primer for audiophiles to learn how speakers/subwoofers behave in-room. BTW Toole is Canadian and worked for many years at the National Research Council (previously known as the Canadian Research Council). He's published many papers. In the book you'll learn that residentially sized rooms have bass peaks/dips of up to 30 dB and the best first step for addressing those peaks/dips is the use of carefully place multiple subwoofers. I say speaker for the given room because you can overload a small room with big full range speakers. Plus small speakers tend to image better and are easier to sell on. Don't get into the big game hunter mentality of constantly being on the search for a new trophy to fill your room with eye candy made up of expensive veneers, a rats nest of wires, and a bunch of fancy faceplates. If you follow that path, you'll only need a pair of monitors, which should be an easier load. Personally I also recommend exploring active monitors for their multiple innate advantages, in which case you won't need a power amp at all. In fact with active monitors and subs you could end up with something like the ($1650 USD) NAD C658 streamer/DAC/preamp plus active monitors and subs and be done. The C658 even comes with Dirac DSP (Digital Signal Processing) to measure/correct room anomalies. Plus the C658 uses NAD's own BlueSound operating system - no extra software needed.
Im with JLM for the most part on this one. The speakers are the true end point of the system and will determine what amplifier needs will be. The speaker/amplifier interface is crucial regardless of whether it’s monitor/sub woofer combo or a full range floorstander. BTW I’m the AC member mresseguei mentioned using the Shiit Aegirs running mono. Good luck!Don P
